msdnga
- Joined
- Jan 29, 2008
- Messages
- 374
- Reaction score
- 0
I sent a STS forged turbo guy home with a 93 octane tune, knock sensors enabled, and with the 10% ethanol fuel, he detonated a plug. Didn't hurt the motor, would have busted a piston had it been stock.
No matter how well someone tunes it, variables can hurt it. Overheating or fuel quality being the first major killers.
You guys have stock pistons that are making 400-450rw from the factory, then moving it to 500-600 with boost. I don't care how perfect the tune is-your piston is not designed to handle that power and pressure. Everyone of you doing this on a cast piston trying to make 700 crank is simply gambling.
No-one would take any project car with plans for boost and decide to keep the factory non forged piston in it. I get razzed all the time because our SRT8 Jeep's fastest times are due to the forged parts. These guys chasin our times are running 175-200 shots on a stock block. How is a forged engine faster than a stock setup? So I chose to forge the engine? That is the only way to go when adding power levels way above factory design. I have a 2009 Challenger with 3 miles on it, twin turbos, and already have a forged engine going in it. No gambling there.....
I have 1 Paxton failure, 2 STS Failures (Flying Low is one), 1 NO2 failure on stock blocks here, everyone the top of the piston fell apart. Not a single forged failure. Nor any oiling failures. All 11.5 to 11.8 AFR.
Forge the pistons and rods, then press on.....
