moparviper
Could my DR kill my top end that much? And how much do you think the shifter getting hung up would cost me? And im replacing the clutch fluid on sunday so hopefully that will fix her.
My air to fuel ratio at 5 thousand rpms is 10.2 and at 5500 rpms its atright around the same
Nope no cal-tracks...just my DRs
You need to buy an A/F ratio Guage which has a wideband O2 sensor that feeds back to the Guage the A/F ratio
Cruise/idle should be 14.7 which means with gasoline that you are burning all air/fuel mixture during each combustion process. Running a tad rich is kinda insurance at Wide Open Throttle (wot) against detonation aka knock aka ping which is harmful to your pistons and rings. A general safe A/F mixture at WOT is 12.5:1. Anything below on an NA engine is leaving power on the table.
