seethrough
Member
i Fail to see the logic or the benefit from this "no boost" intercooler. when the supercharger is under a bypass or no boost condition ,it won't be creating any heat. The heat is created once it starts to compress air. Please explain where this heat is coming from that you need to bypass intercool.
Getting the intake air temps from the PCM isn't accurate either. you want to measure the air temp in the manifold , under the SC . then you can measure air density accurately.
I think you are correct that the supercharger is not compressing the air when the bypass valve is open but I think there is still some heat developed. Maybe just from the friction of the SC rotors and the fact that the aluminum manifold is picking up heat from the engine. I do have a temp sensor tied directly into the manifold and there is a temperature differance between what it reads and what the PCM shows for the ambient air temp. I also noticed last week when it was in the 40s and the truck was started cold that the PCM ambient temp and the manifold air temp were very close with the manifold temp being slightly higher. This makes me believe that the SC does heat the air some . As the engine warmed up the manifold temp and PCM ambient temp spread became greater which leads me to believe that the manifold air is picking up temperature from the engine. Whether the intercooler makes a differance is still a question but I do have plans of installing one to see if there is a benefit.
