how tight do you guys wine your stock engines? Oh and thanks for you input
5500 is plenty.
When I am racing I try to powershift around 5000 to 5200.
5500 is plenty.
Mine flattened at around 5400 and started to drop at 5600.
I think my shiftlight was set to 5000 or 5200.
5500 is plenty.
Sissy, I shift at 6,000 from 1st to 2nd and 2nd to 3rd, then at 5,600 3rd to 4th during my 1/4 mile runs. I have 63,000 miles on the stock engine and have had no issues. I also have a ported intake and a tune, but I was using this method long before I had the ported intake. My peak hp has always been at 5,600 and peak torque from 4'100 to 4,300 rpm.
I did go with a different gear set ratio this week, I'll post up if it helped or if I screwed myself over. Lol
What gear ratio are you using now?
in an auto, i bet the 4.88's would help...
We're gonna find out tomorrow, I'll either post up happy or pissed. Trainman predicts 121 mph @ 6200. I like to push the envelope, so we'll see. Worse case I have thd gears if I go six speed ala VENOMOUS.
Drop back about 500 rpm and see if your ET picks up.
Somewhere north of 6000. It really helps recovery with an auto trans. Yet ONE MORE reason to PULL THE HEADS when you are swapping a cam; to make sure the lifter holsters are in good enough shape to withstand the increase in RPM. And higher spring pressures.
So are you in agreement as far as high shift points vs lower?
