Thanks for the input guys! I have learned quit a bit about the forced induction systems. I think I will pass on the STS and do some more research on my other options (Roe Supercharger, Paxton, and Proturbo)
LitemUp said:Thanks for the input guys! I have learned quit a bit about the forced induction systems. I think I will pass on the STS and do some more research on my other options (Roe Supercharger, Paxton, and Proturbo)
mauiSRT/10 said:Excellent decision dude..........was it the the screwdriver in the eye deal that convinced you?:dontknow: LOL
patrick
Stinker said:if you want "only" 700hp
Nowwhat said:pipe down junior....I am pushing 1000rwhp..... ....just takes a bit o' laughing gas....
Stinker said:I no need no gas!!
jsut outta my ass
Silverback said:With the STS, the back pressure is the greatest when it's under boost. It's the back pressure that is spinning the turbo, not the heat energy with normal turbo systems. During normal driving the turbo is pretty much a non issue. When the STS builds boost pressure the back pressure has to be greater than the boost pressure in order for it to generate boost.
Now you have EGT's gauges on your helicopter to tell you when something is going wrong. Ever had it happen? For whatever reason those EGT's can spike in just a couple seconds. Same in your engine. Problem is you will not see it unless you have EGT probes in every exhaust port. Needless to say the cooling system will be to slow to react to show that you have a problem. By the time it does you have already lost an engine.
You could run pure methanol for fuel, and have an inter-cooler, and it would not do a damn bit of good with the STS system.
FlyingLow said:With all that in mine is it just an issue with our engines or across the board. Lots of other engines out there with the STS system.
Anyone know if the vipers have the same problem for those that have the STS on theirs? I'm not on the viper boards so I thought some of you might have heard some info.
Stinker said:no one that I know has installed a STS on a viper.
I do know this tho, after all the hell I have endured, I havent run into one major tuner yet that wants to tune ANY turbo system on the Gen III with piston and rod upgrades.
Havent never really asked, figure Silver has is pegged, but evidently SC boost and tune is considerably internally different from turbos.
They say Sc's is no problem but that Gen III's jsut cant take the pressure from turbos unless kept below 4or5psi area, and thats where a Sc'r shines in a stock engine.
Silverback said:Yes, boost is boost, and the engine does not know how it got there from the intake side of things. However, if the exhaust is restricted, like the STS does, it will make a big difference to the engine, as the majority of STS owners have found out.
AWDisuzu said:the sts needs a bigger turbo or 2 of them!
Dave T(BADVENM) said:Who will be doing your tune? You've made the right choice. Doug Levin knows paxtons like the back of his hand. Of course Roe knows their systems. Underground would be the way to go if you're going turbos.
FlyingLow said:If I can't run over 5 psi then how would a bigger turbo help?
LitemUp said:I'm leaning towards the paxton since Doug literally in my backyard, but I kinda like the Roe SC a bit more.
FlyingLow said:So was the problem with the all the other guys that lost an engine back-pressure and not tuning? Or does it somehow all tie in together? Please understand John that I'm not questioning you, I'm just trying to get a better understanding of it all. I thought the problem with all the others was over-boost or tuning and no so much heat build up or back-pressure.
Dave T(BADVENM) said:From what I've read you cannot go wrong with Doug. I'll bet he can get more out of the Paxton than what you'll get out of the Roe.
LitemUp said:I'm really considering in purchasing an STS turbo kit for my truck....
Thanks for your help... Looking forward to your feedback
