I got the car back today and it still leaks. Although it is the best that I have noticed. So far the work performed has been the drain tube TSB, a complete new sunroof assembly, new headliner, and today it was just a seal. When the service department called me to tell me it is done, I asked them did you run it through an automatic car wash? He said no. I tell him than it still leaks right. His reply "I recommend you not run it through the automatic car wash." I tell him it is a brand new car and with todays technology you would think you could build a sunroof that does not leak through an automatic car wash. And if it is a small leak now it will only get worse. Then I am out the money to replace a ruined headliner because of a defective part. The service manager understood my point, but acted like his hands were tied and was not going to do anything else to fix the matter.
To top it all off I found some new problems. The roof rack rails are installed wrong. I can barely get the cross rail on the farthest back position because the rails are too close together. I can see the rails spreading apart and have to use quite a bit of force to get the cross rails down. Plus now I can smell oil burning from the engine compartment. There are no oil spots on the ground and I can't find any obvious leaks.
