The Engine Build
Right! He has as very :cool: Fleet! Definitely class act in my book - they are in my moms town I'm thinking on getting stuck next visit so i can see their rig up close! Hahahaha
Ill bet he charges a ton .. But hey maybe you will get a T-shirt hahaha
I would get a t-shirt! Starts at 500.00 and rapidly goes up from there lol
Expensive t/shirt! Hahah
Maybe the have a senior discount :D:p
Started the job of putting it back in.
A few issues.
The clutch release bearing is different, no idea how to fit or even if it does fit.
Fuel hose connector to fuel rail has broken o rings so that won't go back on.
Probably just cut the swaged fitting off further back where it is attached to the pipe and replace it with 8mm hose.
View attachment 68450View attachment 68451
A few issues.
You cant replace the O-Rings ?
My thought is using a piece of hose with the fuel pressure being higher on fuel injection and using a new more Hp fuel pump may not be the best thing and possibly rupture over time .. at least something to look into .
Im not sure what the clutch release bearing is or where its located ????
Ooooh! Looks so nice! Good luck working out the bugs!
Yes the motor sitting there looks pertty .. but clean up a couple pully's and that dirty looking zit of a Alternator hahaha . Polish up the thermostat housing also
Ok i got it ,, I call it the throwout bearing
Yes!!!! NEVR DULL lol
Slight delay. The throw out bearing is wrong so have ordered a new Slave cylinder from Rockauto.
Just talk quietly amongst yourselves.
Normal transmission shall resume shortly.
Thank you for your cooperation.
I'm surprised they still call it that hahahaha!! Glad they had one
We're almost there!!! Yayyy!!
Throwout bearings I would hope should always be avail. i would think ..
Im not sure since I have a automatic . So what do they have to do with hydralics if so !
Says Slave cylinder causes throwout bearing to move .. not sure why he needed new slave and not the bearing so will see when he posts
Dont forget the oil lol !
What oil will you be using on the breakin ?
I noticed your using a WIX oil filter ! What made you choose it ?
