robwclark
Been running fine up until today. I started it up and drove about 5 miles, about a mile down the road it started acting up.
The truck has a full built motor, twin garrett 35's, water to air intercooler, Full Aeromotive stand alone rising rate fuel system with 4 extra injectors in front of the TB, about 1000HP at 9lbs of boost, I drive it everyday, but heavily modded, you guys get the picture.
At idle it seems fine, but it runs rough off idle and loads up pretty bad. Fuel Smoke comes out the pipes when it does it(which is most of the time), and cuts out all the way up the rev band when you rev it up sitting still. When normal driving under little load, it still loads up horribly, & cuts out badly, I dont dare put any boost to it.
I have a DRBIII and the only 3 codes are "rich condition bank 2" which I already know, and "map sensor voltage too high", and one more code that it always has about O2 sensor voltage low bank 1 sensor 2. I'm almost certain a new O2 wont cure this problem. I ran an injector kill test, and an IAC idle test with no missfires at idle. It seems to idle pretty good, but as soon as you touch the gas it loads up. Some times it even does it at idle after you come to a stop it almost dies. I just put a new crank sensor in and didnt change a thing. Oh and fuel pressure stays 100% normal at 37-39 psi while all the loading up & cutting out is going on. Any of you educated guys have any idea where to look next. Map sensor maybe, but I doubt it? I'm a pretty capable mechanic myself, but with no codes and all the mod's im lost. What could be causing the injectors to overfuel like this??? Anyone else ran into this problem or one similar? Thanks in advance.
