Itsmekylep
So please ejholt, can you pimp my ride???
send him your check book!
Jesus.... 4x Rockford Fosgate T2 subs?! Ive got 2 in my Avenger and they are insanely loud!
Is that enough space in that box for subs that big? I thought those subs needed a lot of room in the enclosure to function properly. My box has 2.0 Cu FT for each sub.
Just need to finish up the wiring for the LEDs that run around the subs and put in the middle Rockford Emblem and the box is good to go. Hard to believe this is going to fit behind the seats and allow you to put them all the way back..... :rock:
Honestly, the best looking truck on the forum hands down.
Amazing work. Absolutely amazing. I am so impressed that you were able to put those T2's in there. You just added like 400 lbs of weight to the truck though lol.
Nice work. Keep the updates coming.
What are you using for an alternator? I am thinking of upgrading mine and am looking for ways to go.
I swapped out the alternator back in 2005 when I bought the truck and built the 1st system. I think it came from Ohio Generator and was around 300 amp.
It was never enough to push what I had in the truck at that stage, the volts would just drop when the truck was at idle.
This time around I've added 5 - XSPower D6500 Batteries. Got 1 under the hood and 4 going against the backwall in the bed, behind plexglass. Each battery is rated for 4,000 watts each, so I'll have 20,000 watts and that 300 amp alternator to support the system. More then enough to keep it going and not put any stress on it. Each battery weighs 60lbs. I've easily got over 1,000 lbs in audio equipment.
Then again, that is why I have all that power. The weight of that audio equipment will hopefully keep that truck straight when I put the power down.
I don't mind the weight if I'm not trying to make my truck a track vehicle. In your case, I wouldn't dare put that beauty on a track with the intentions of winning races. Just fun.
I'm afraid to take it anywhere, as I don't want anyone getting near that paint. Not easy to fix a $40K custom paint job...... Never mind dealing with rocks and chips, etc. on the road.
