Weight Reduction (List)
FATJACK said:
What happened to the weight reduction thread???:mad: :mad: :mad: :mad: :mad:
Ok let me make it up to ya.
I pulled off over 7 lbs off of the tran cross member and there is more to loose.
Pulled 3lbs off of the mounting plates for the bumper the ones on the frame. Pulled another 2 out of the bumper more can be pulled if so desired. The brackets for the fog lights can be cut to loose some, not a pound but it all adds up. 3/4 of the pcm mounting bracket weighed 3lbs. All excessive length bolts can be cut (cut even with nut) . Spare tire mount is over 20lbs But really not recommended unless you know you can dead hook already. Behind the headlights can be cut out its part of the fender that you never see. The mat on the fire wall is worth a few lbs.
Better?:D
