slinkypete
thanks Ronnie
Thanks, i didn't know if it was offset keys or multi keyway crank sprocket. I'll pull the heads when I get your cam. about the head gaskets i'm thinking you are referring to the thinner affordable gen 4 head gaskets?
Hi
I use conventional equipment for degreeing the cams in the Gen IIIs. If you are pulling the heads (recommended) you can determine T.D.C. accurately and safely plus you will benefit from a 0.4 increase in compression using the replacement head gaskets. You can also check for any preignition cracks your piston crowns may have (hopefully not) or any other abnormalities.
The O.E.M. Gen III chain set is decent. Changes can be made with offset keys, if required.
Ronnie
