WTF
Assembled Strikers, valve cover spacers, a new custom-grind billet cam, gaskets and a tune settled in at around 10 grand; doing the work myself.
The resulting horsepower level exceeded the capacity of my o.e.m. fuel injectors, so add another couple of grand there...
Things are happening. Dealing with John at Southeast Performance.
Questions:
The oil cooler, is it full flow? I am thinking of removing it all together and just looping with a short hose/pipe. I have before used a small electric pump, taken oil from sump through a air/oil coolerand back to sump. With a manual switch and used only when needed. With our temperate climate and daily running I won't really need it alot. I did that on my old Vauxhall race car as when not being raced I didn't need it and the extra length of pipework and cooler puts more drag on oil system. Also if you did suck some air under extreme braking, it was gone before power went back on rather than be some out there in external filters and coolers. I saw a lot of expensive engines fail, I believe, that is what happened.
0 deck height. I agree. Piston flush with top of bore. Tell me the science please.
With the better heads should I stay at 10.5:1 comp. Enjoy the extra safety margin.
Should I trust John with parts choices and cam profile?
If you look carefully.... has anyone noticed anything changed? .......
JUST PLUM CRAZY #234 Build Date 5pm Dec 10th 2003
Stri...Volant CAI, JTS Venom TB, U/D Pulley, 10.5:1 Comp, Catch Can, Tuned by Torrie, Demon Coils, Live Wires, Belanger Headers, Catless twin 3" Exhaust with electric cutouts, 2.5" tail sections with hot dogs. Train Horns, Right Hand Drive!
Crazy Old Man Behind The Wheel.
I’m lost ?
Questions:
Not sure about the efficiency of the oil systems on these trucks ?
Removal would have the cooler to me doesn’t seem to be beneficial . Keeping the oil cooled is a good thing . If it affects the oil flow then yes a better system would be beneficial .. What about a Dry sump system ? Is what you’re saying by removing the cooler will it really help or improve oil flow/ less restriction with less chance of cavitation , sucking air ? The truck have a large amount of oil in them already and the pick is deeper into the oil high I would think old lesson the chance of sucking air unless the oil level was excessively low . Is what your proposing my thoughts may be helpful for priming the oil system after sitting overnight getting oil to vital parts sooner .. But then again I maybe misunderstanding what you’re intending as my brain is on overtime as another crazy old man lol ..
No I can't find it! -
No more juice and milk in 2 litres??
Have,you figure out the block situation yet ?
Step by step ,, inch by inch , pics and vid’s and a completely write up is a must … exciting rebuild to say the least !
@Kiwi SRT10 - now complete the sig line! Stri...
I see what you did with M I N E ! - clever :)
Questions:
Make sure to use an O2 compatible sealant on the threads of the fasteners that pass through the sidewall of the Intake Port on the Strikers (if you decide to use those heads). If you dont, you will have an air leak past the threads.
AND... dial back the torque by about 40% on those fasteners. Dry torque and wet torque have considerably different values. Strikers use Helicoils, but Aluminum has some pretty abrupt torque limits at times.
A great choice for a cam is in the 228-232 range at .050". Mine is ground on a wide 115 degree L.S.A and still has a nice lope at idle. Too much more duration and your e.c.u. WILL complain. A cam like this will give you a WIDE torque band and around 170 cranking compression at sea-level and 13" at idle, (operating temp). In other words, that late(r) closing Intake Valve doesn't close so late that the cylinder can't build good low r.p.m. pressure, a.k.a. TORQUE. You could also split the duration between Intake and Exhaust. As I'm running 4 Cats on my truck, I added 6 degrees duration to the exhaust profile; a definite advantage when you design your own cam profile! .650" lift is a good target number.
Whoever is building your engine also needs to DEGREE the camshaft as some of the chainsets released by Lamborghini were whacked and the camshafts were factory installed really late. I.O.W. simply lining up the dots isn't good enough. It never is, but particularly so with the Gen III. I'd also HIGHLY recommend a positive-stop method for finding T.D.C. prior to degreeing the shiny new cam.
Set your valve lash at TWO FULL TURNS (if you go with Strikers) and o.e.m. Lifters (recommended).
This is VERY important with either the T&D Rockers or the Jesel for maximum power.
10.5 : 1 would be a great target for pump gas with Strikers. 10.75 is also fine with pump gas as you are zero-decking (?) AND Strikers have a high-swirl and fast-burn chamber.
With Strikers and related parts, you will be over 700 horsepower crank, which is beyond the design capacity of the o.e.m. injectors. The rest of the trucks' fuel system is plenty good enough. As pulse-width tweaking in the tune controls the injector, I wouldn't go too wild on capacity as it REALLY makes tuning much trickier and is unnecessary. Unburned fuel kills oil and accelerates engine wear. Again, the injectors JMB offers work (but are physically shorter) and an Intake Manifold tweak is required to get the spray-tip out of the well far enough so they don't puddle. If you do this now you won't have to retune for A/F changes later.
You can get higher capacity injectors through JMB Justin or maybe the guys you are dealing with for heads.
If you decide to use some properly ported Gen III Heads you will be down around 50 horsepower (compared to Strikers) and your o.e.m. Injectors will be enough.
Plugs: NGK LFR6A11 @ .040
20 ft. lbs. NO thread goop.
You WILL need a good tune to pull it all together.
Best of luck!!
