what transmission did they use on the 2500 with the v-10 i know it was geared lower, no doubt there.
you get 14 mpg towing a trailer? i cant get that empty.
the boat is a cruiser, and i only towed it 10 miles arround my block to see how well it worked.
if i had a crash, there would be no way to know if it was designed to tow, and then u-haul would share a responsibility for installing a hitch.
suspension has an overload spring on it, that say's "tow with me"
two things might happen with this truck in the long term....
1 i use it to tow my boat,
and i use it to tow the fifth wheel trailer.
2 it gets traded in for a $175,000 motor home
i have not made my mind, but for $160 i put a hitch on it to test my theory....
if it did end up towing the fifth wheel i would put a new rear end on it. maybe a 5:1.
i like the truck and would love to run about in flordia this winter in it, but i need to find the best solution.
i am leaning strongly at this point toward the class-a motor home. in the spring i would then pick up the gts.
