towing 101
Smokey said:
i started looking into this alittle deeper...it seems the dodge does not give the RC a carrying capacity OR tow rating, the fact that GVWR is only 6600lbs fully suports this.
The RC is only made to haul ass and not much else
THIS!
I just read 9 pages and am completely suprised it took so long for this to be mentioned! This is exactly true! The regular cab should not do any type of heavy towing! It doesnt matter if you have 15" brakes or 500hp etc etc.
It's a suspension, drivetrain, short wheelbase issue!! A safety issue!
Not only won't the clutch or weak viper transmission from a 3400 lb viper now being installed in a 5200 lb Ram hold up, like mentioned the suspension is not up to the task. Having the shorter wheelbase of a regular cab truck with weight like that behind you, NOT SAFE!!
The frame is a regular old Ram 1500 frame, not a 2500 frame. The ONLY Ram SRT-10 to get the "upgraded" 2500 frame was the 2006 Quad Cab. (remember, they dont make standard cab short box 2500s ;) )
Then there is the fact you have the 4.10 gears.
If you want to tow, get a quad cab. You get a longer wheelbase, 2005 upgraded brake calipers, the automatic from the diesel with a heavy duty torque converter and 2 piece driveshaft with 4.56 gears. Also the transmission control module has calibration for towing.
Even then the Quad Cab "only" has a towing capacity of 7500 lbs, that you were clearly over..
:congrats:
ACRucrazy said:
THIS!
:congrats:
Everything you have stated is not really true about about the trucks (as far as towing) it is strictly warranty issues ( mostly clutch and transmission) The truck 6 speeds have bigger gears than the viper car ( to handle the weight)
Auto makers do not usually offer a towing package with stick tranny's, that is the reason for no tow rating !!! A warranty issue.
My Furd f350 4x4 did not have a towing package available unless it came with an automatic trans, so I had to special order and build it piece by piece out of the order sheet to get it with a stick tranny ( warranty voided) if used for towing and that is a full 1 ton truck:mad:
Most people can not even drive a manual type tranny equipped vehicle any more , there in lyes the problem. The makers do not want the warranty repair expense because of morons not knowing how to use a clutch so they have attempted to minimize their liability by only offering the automatics on tow vehicles.
Do some more research( like try to get a towing package with a stick tranny on any brand. These trucks can tow if you can drive. My .02 cents
scoobert said:
prof, correct me if i am wrong doesn't this come down to gearing and clutch?
or are there other things beyond sight that prevent towing?
You are so ignorant it's amazing you can type this f*cking bullshit you post.
I'm not even going to attempt to explain it to you as you are not worth the effort.
And for the rest of you. The sooner you put this bilthering idiot on "Ignore", the sooner he will go away.
Ram 2500/3500 Hemi/V10 manual trans for starters?
Click 1
Click 2
There is a reason why the 2500/3500 Rams never cam in a standard cab/shortbox. Wheelbase for starters.
Not looking to start a finger pointing war, but someone claiming to tow 4 tons with possibly towing 6.5 tons with a reg cab SRT-10 is laughable.. In a dangerous sort of way.
includemeout said:
You failed !!!!!!!!!!!!!!!!:marchmellow: :slug:
:D
My first reply didnt get posted, said admin may choose to approve message or something so I tried a quick reply. :dontknow:
The basics:
Officially announced; these specs confirmed 11/03 (published 2/03!)
0-60 in 5.2 seconds
13.8 second quarter mile
.92 g skid-pad
World's speed record set February 2, 2004
When the Dodge V-10 was first introduced, there were two very different versions: the race engine, used on the Viper, and the torquer, used on the Ram. A V-10 powered Ram 2500 truck was, in truth, similar in feel to a 318-powered 1500, since it was meant for towing more than acceleration.
No more.
The newly augmented Viper V-10 is used, intact, on the Ram SRT-10. With 500 horsepower and 525 lb-ft of torque, it is the fastest truck available. Created by the new Performance Vehicle Operations (PVO) team - Chrysler's version of SVO and AMG - the truck used Viper and Prowler engineers along with the teams responsible for NASCAR vehicles and Le Mans Vipers.
SRT-10 is based on the standard SRT name given, confusingly enough, to vehicles modified by the PVO Group - that's Performance Vehicle Operations. SRT originally stood for "Street and Racing Technology" but now stands for "Strip, Road, and Track" - similar to the old R/T designation which seems to have been abandoned.
Ram Home | 2010 Ram HD | Reviews | Repairs | FAQ | Vans | History | Symbol | Cummins | forum
CURRENT/RECENT: 2009 Dodge Ram | 2002-08 1500 | 2002-08 3500/3500 | Power Wagon
CHASSIS CABS: 2007-10 Ram 3500 | 2008-10 Ram 4500/5500 | 2011 Chassis Cabs
VINTAGE: SRT-10 | 1960 | 1966 | 1975 | 1977 | 1983 | Campers, Motor Homes | L’il Red Truck | Sweptside |
World's speed record (February 2, 2004)
Only recently off the Saltillo, Mexico, assembly line and not modified in any way for additional power or enhanced aerodynamics, a Dodge Ram SRT-10 posted a two-lap, both-directions average speed of 154.587 mph over a "flying kilometer" on the 4.71-mile oval at the Chrysler Proving Grounds here in Chelsea. The record run by the Dodge Ram SRT-10 was certified by Guinness World Records and the Sports Car Club of America (SCCA). The previous record was 147.54 mph, set last July by the Ford SVT F-150 Lightning, before the Dodge Ram SRT-10 went into production. (This record has now been broken by the Holden LS2 6.0 litre V8 Maloo R8 Ute, at 168.7 mph.)
Behind the wheel of the Ram SRT-10 in the record-setting run was Brendan Gaughan, a six-time winner in a Dodge Ram in the 2003 NASCAR Craftsman Truck Series (NCTS). Gaughan makes his NASCAR Nextel Cup debut later this month at the Daytona 500 in the No. 77 Kodak Dodge.
Hein Le Roux, research team member at Guinness World Records, said "People aren't too surprised when they hear about expensive super cars or race cars setting speed records. But few people expect a standard production pickup truck, which they can drive straight off the dealer lot, to be capable of this sort of speed. That's what makes this such a great Guinness World Record." (For more, see our news archives.)
The production version - first shown February 13, 2003; confirmed November 18, 2003
Trevor Creed, Chrysler's Senior Vice President of Design, said: "We spent a lot of time in the wind tunnel with the Ram SRT-10, so that is why you see a deep front fascia with a splitter and a subtle rear wing. In fact, we have managed the aerodynamics of the Ram SRT-10 to give this vehicle performance more befitting a sports car than a truck. The rear wing is not only functional, providing a reduction in lift, but it also provides a reduction in drag, which is a rarity for a wing."
The most noticeable exterior feature of the new 2004 Dodge Ram SRT-10 is a unique hood that features a wide power bulge and scoop sitting atop the signature cross-hair grille. "Viper Powered" badges on either side of the hood scoop leave no doubt as to what resides underneath.
The Dodge Ram SRT-10 is available in black, red and silver only. The Ram SRT-10 rides on unique 22-inch polished aluminum "Viper-style" wheels, the largest wheels available on production pickup. The new front fascia, unique hood with integrated air intake, billet grille, lower ride height and ground-effect moldings make it look "hunkered down."
From the side, effects include an aluminum fuel filler, SRT-10 badging, and visible red brake calipers; from the rear, they include a spoiler and custom fascia with cutout for dual exhausts and a large, center-mounted chrome Ram's head badge.
"There is a slightly understated air about the SRT-10, especially considering its performance potential," said Rick Aneiros, Vice President, Truck Design. "But as powerful as the overall theme of the Ram SRT-10 is, we were determined not to make this another boy racer truck. We added functional aero tweaks to deliver a truck that can handle 150 mph-plus speeds."
Inside, there are heavily bolstered racing-derived leather seats with black suede perforated inserts and a carbon-fiber leather trim steering wheel. Silver trim adorns the center stack and a silver trim strip with an "SRT-10" badge resides on the passenger side air bag. A red Viper start button on the dash goes with the engine, and a custom Hurst shift lever sprouts from a silver metal shift bezel and is topped by a Viper style shift knob. Aluminum performance pedals replace the stock set up.
A new gauge cluster with satin silver-faced gauges feature Viper font and graphics and appropriately recalibrated speedometer and tachometer to accommodate the SRT-10's visceral performance.
Drivetrain
Resting on unique engine mounts, the new V-10 engine delivers 90 percent of its whopping 525 lb.-ft. of torque from 1500 to 5600 rpm. The all-new cast aluminum cylinder block has interference-fit cast-iron liners and cross-bolted main caps. Both bore and stroke have been increased over previous Viper models. Block length, block height, bore spacing, firing order, rod length and compression ratio are unchanged.
The Viper V-10 includes a six main bearing crankshaft with increased stroke length and cross-bolted main bearing caps. All-new cast aluminum alloy pistons — weighing slightly less than prior years despite larger diameters — are included, as are all-new cracked-steel connecting rods that are lighter yet stronger.
Cylinder heads on the Viper V-10 are redesigned using semi-permanent mold (SPM) 356 T6 aluminum alloy, with improved intake port, exhaust port and combustion chamber cooling. Lower-profile die-cast magnesium cylinder head covers with steel internal baffles and anti-slosh foam also are new for 2003.
A single-piece, central dual-plenum, cast aluminum intake manifold is also new. It boasts shorter runners and a single, non-staged two-barrel throttle body for higher peak horsepower RPM. The intake manifold is an all-inclusive Integrated Air and Fuel Module (IAFM) with tubular fuel rails, injectors, sensors, wiring and throttle body — delivered assembled and pre-tested.
A Ram heavy duty cooling system is modified to handle the needs of the new Viper engine. A custom dual exhaust system is mounted to new exhaust manifolds. The Ram SRT-10 also features a unique oil pan, throttle linkage, transmission mounts, exhaust manifolds, and radiator.
The 2004 Dodge Ram SRT-10 focuses its power through a new Hurst shift linkage and a modified version of the Viper SRT-10's Tremec T56 six-speed manual transmission. The T56 is fully synchronized with electronic reverse lockout. A new 4.5-inch aluminum driveshaft runs to the Viper-sourced transmission and a modified differential with a Dana 80 4.11 rear axle delivers the torque to the road.
Suspension
The engineers at PVO modified the Ram Heavy Duty's rack-and-pinion steering and independent front suspension. Working with the fully hydroformed Dodge Ram frame, one of the stiffest in the industry, PVO added a custom tuned suspension, dropping the Ram SRT-10 one inch at the front and two inches at the rear. New front and rear strut assemblies and a rear sway bar were added to handle the increased cornering loads.
Next came Bilstein shock absorbers, performance-tuned springs, unique aerodynamic aids to enhance the Ram SRT-10's higher speed performance, and 22-inch custom "Viper-style" wheels and 305/40 Pirelli Scorpion tires.
Big brakes, another Dodge Ram staple, are also part of the equation on the 2004 Ram SRT-10. The standard ABS-equipped brakes are fitted with new 15-inch rotors on the front brakes. Rear brakes are modified Ram Heavy Duty 14-inch rotors. Front and rear brakes feature unique red calipers. The new front fascia features brake ducts to provide plenty of cooling for track sessions.
"The Dodge Ram SRT-10 delivers simply phenomenal handling," said Dan Knott, Director-Performance Vehicle Operations (PVO). "But without sacrificing ride quality. This is a truck that you can run to the store in, and then start tackling apexes on your favorite set of twisties. And, depending on your right foot, the V-10 can make the straightaways really short."
Big brakes, another Dodge Ram staple, are also modified for the 2004 Ram SRT-10. The standard ABS-equipped brakes are fitted with new 15-inch rotors on the front brakes. Rear brakes are modified Ram Heavy Duty with 14-inch rotors. Front and rear brakes feature unique red calipers. The new front fascia features NASCAR-inspired brake cooling ducts to provide plenty of cooling for track sessions.
Specifications
Two-seats, V-10 engine, 90 degree V-type 8.3 liter (505 cubic inch)
Horsepower: 500 bhp (372 kW) @ 5,600 rpm
Torque: 525 lb.-ft. (678 Nom)@ 4,200 rpm
Manual, six-speed transmission with Hurst shifter mechanism and linkage
Wheelbase: 120.5
Box Length: 6'3"
Track, Front: 68.5
Track, Rear: 67.9
Overall Length: 203.1
Overall Width: 79.9
Overall Height: 74.4
Fuel Tank Capacity: 26 gal
Curb Weight (estimated): 5,000 lbs.
Tires: Pirelli Scorpion Zero 305/40 YR 22
Wheels: Forged aluminium "Viper-style" 22 x 10 inch
Performance (estimated)
0-60 mph 5.2 sec.; 0-80 mph 8.4 sec.
Standing quarter mile 13.8 sec. @106 mph
Top Speed 150 mph
About the 2002 concept version of the Dodge Ram SRT-10
The Dodge Ram SRT-10's power is channeled through a Viper six-speed manual transmission that connects to a modified differential and new driveshaft. The Ram SRT-10 will accelerate to sixty mph in an estimated 5.0 seconds and deliver an estimated top speed of 150 mph. More impressively, Ram SRT-10 runs the 0-100-0 mph dash in an estimated 18 seconds.
These figures beat nearly every vehicle made in the US, going back as far as you care to look. As a comparison, the Spirit R/T ran 0-60 in 5.8 seconds, and was the fastest four-door production car in the world during its time. The turbocharged, 220 horsepower Neon SRT-4 runs 0-60 in 5.9 seconds. Most "ordinary" cars run 0-60 in around 9-10 seconds now [2004], down from 12 seconds a decade ago.
Keeping all this power in check is a modified rack and pinion steering and independent front suspension from the 2002 Dodge Ram, which set new handling standards for full-size pickups. Blessed with the stiffest frame in Ram history, the Ram SRT-10 makes the most of its exclusive 24-inch wheels and 305/35 R24 high-performance tires, pulling an estimated 0.92 g's on the skid pad and hitting almost 70 mph on the slalom. A recalibrated, quick-ratio power steering unit enhances steering feel.
The Ram SRT-10's handling is enhanced by the addition of performance-tuned springs and shocks, a rear sway bar and an inch-lower ride height. Bringing the Ram SRT-10 to a halt are four-wheel disc Viper brakes, equipped with standard ABS. Fascia-mounted, faired-in brake ducts aid cooling.
The exterior appearance of the Dodge Ram SRT-10 imparts an almost sinister demeanor with a design that blends the bold, "big-rig" look of the 2002 Dodge Ram with performance styling cues that hint at the extra muscle behind its signature cross-hair grille. It's understated "muscle truck" exterior sends a quiet yet unmistakable message that the Ram SRT-10 owns the fast lane.
Available in black or red only, the crisp lines of the Dodge Ram SRT-10 provide a look of machined elegance with a lower -- and an even bolder -- stance than the standard Ram. The new front fascia, hood with integrated air intake, billet grille, one-inch lower ride height and ground-effect moldings provide plenty of "hunkered down" attitude even before the ignition key is turned. From the side, Ram SRT-10 is distinguished by an aluminum fuel filler, SRT-10 badging and red Viper brake calipers visible behind the 24-inch wheels. A bed-mounted hard tonneau, spoiler and custom rear fascia with cutouts for dual exhausts provide the view for the majority of the motoring public.
Inside, red-piped leather and carbon fiber-look accents complement the performance attitude established by the SRT-10's outward appearance. Silver-faced gauges with Viper font and graphics have an appropriately recalibrated speedometer and tachometer to accommodate the SRT-10's visceral performance. Interior space is maintained from the standard Ram.
Dodge Ram SRT-10 Quad Cab
Following on the success of the Dodge Ram SRT-10 regular cab pickup, Dodge introduces the Ram SRT-10 Quad Cab, targeted directly at the truck enthusiast who wants SRT performance in a pickup with room for the family and towing capacity.
"We knew when we came out with the world's fastest production pickup that there would be customers who would want that same ultimate performance, but in a pickup that offered four-passenger seating and towing capability," said Dan Knott, Director — Street and Racing Technology (SRT). "So, the question was, 'Can we create a more usable truck for the person who wants to haul more stuff, but is not willing to give up performance?'"
The engine is backed up by a four-speed automatic transmission — a 48RE gearbox, specially adapted from a diesel engine application for its ability to handle monster amounts of torque. A heavy-duty torque converter, custom transmission calibration and two-piece drive shaft were also specifically chosen for overall powertrain integrity and performance. Additionally, the Dodge Ram SRT-10 Quad Cab was fitted with a 4.56 gear ratio to improve launch feel, low-end acceleration and towing capability of up to 7,500 pounds.
SRT engineers began with a fully hydroformed frame as the basis for strength and rigidity. From there, the Ram SRT-10 Quad Cab was fitted with fully-tuned front and rear strut and spring assemblies. Up front, modified steering and independent front suspension carry the load, while in the rear, axle snubbers, performance-tuned springs and Bilstein monotube shocks keep things firmly planted through the corners.
Dodge Ram SRT-10 Quad Cab's braking system was designed by SRT engineers, utilizing heavy-duty Dodge Ram components and unique four-pot opposed-piston calipers that are new for 2005. A three channel anti-lock braking system (ABS) actuates new custom red brake calipers up front that grip 15-inch rotors, and in the rear, modified heavy-duty red calipers grip 14-inch rotors. Front brakes are cooled with air ducted from the front fascia to reduce heat build-up.
Featuring cues reminiscent of Dodge's NASCAR Craftsman Truck Series Ram — such as the deep front fascia equipped with a wind splitter, signature cross-hair grille and sculpted sides — the Dodge Ram SRT-10 Quad Cab features a unique hood with a fully functional air intake that provides added bay cooling. A body-color aluminum tonneau cover, outfitted with a unique spoiler for aerodynamic balance, is standard.
Performance cues inside the Dodge Ram SRT-10 Quad Cab include the Viper-like pushbutton starter, race-inspired, grippy and heavily bolstered seats, a leather-wrapped carbon fiber-patterned steering wheel and brushed metal accents on the instrument panel and door trim panels.
The basics:
0-60 in 5.2 seconds
.92 g skid-pad
No more.
Drivetrain
Suspension
Specifications
Wheelbase: 120.5
Box Length: 6'3"
Track, Front: 68.5
Track, Rear: 67.9
Overall Width: 79.9
Top Speed 150 mph
includemeout said:
Hauling more than 5 bags of groceries :D :D :D
The basics:
0-60 in 5.2 seconds
.92 g skid-pad
No more.
Drivetrain
Suspension
Specifications
Wheelbase: 120.5
Box Length: 6'3"
Track, Front: 68.5
Track, Rear: 67.9
Overall Width: 79.9
Top Speed 150 mph
The basics:
0-60 in 5.2 seconds
.92 g skid-pad
No more.
Drivetrain
Suspension
Specifications
Wheelbase: 120.5
Box Length: 6'3"
Track, Front: 68.5
Track, Rear: 67.9
Overall Width: 79.9
Top Speed 150 mph
WOT said:
QC's are tow rated for 7,500 lbs. I pull a 3,500 lb trailer all the time (2 3-seater jetskiis plus toolbox, etc). I can pull it at 70-80mph all day long and the temperature never even creeps up. I have pulled it 500 miles at a time, and you can barely even tell it is back there. I wouldn't want to try 13,000 lbs though.
The basics:
0-60 in 5.2 seconds
.92 g skid-pad
No more.
Drivetrain
Suspension
Specifications
Wheelbase: 120.5
Box Length: 6'3"
Track, Front: 68.5
Track, Rear: 67.9
Overall Width: 79.9
Top Speed 150 mph
ACRucrazy said:
:D
Ok, you get a C+ for trying hehe:D :D ;)
Old post but....
Dodge had to do a buy back on all of the Dakota R/t 360 that they produced due to
the lowered ride height. It changed the angles on the drive shaft,causing failures.
Mine was one of them. Don't remember the model year.
