So they took it apart without your permission?
They should have touched nothing!!!! Go ahead and get the head pulled and see what's up. They better not have removed the F'n spring and pushrod and fired the damn engine upThe valve was likely in tact as the keepers look fine! Then they removed the keepers and maybe the valve is stuck in the seal or they jammed it by cranking the engine over:dontknow:
They should have not removed a dang thang![]()
I asked the Service Manager this morning was the valve up or down when they removed the broken parts, he said the valve was jammed in the up position and that they drove it to the back lot with no issues.
Yes all of this has been very stressful as I love my truck like everyone else on here does. Depending on the condition of the piston & cylinder walls kinda sets the stage for my course of action. I can only guess the piston struck the valve. I may pull the motor and go forged. I'll have to sale my 55 Ford F100 and save some cash to do it. Options are on the table, Strikers, Forged, Cammed....maybe Forged & Blown. I'll figure it out this weekend.
but have seen dozens of pushrods bent due to rocker failure, over revving, or broken springs.
You mean like what could happen if someone grabbed second instead of fourth?(hypothetically, of course)
That's nice you are ready to mod her, but they are being dillholes at thier approach. They should have NEVER driven it period! If the keepers are in tact which it looks they are the piston did NOT hit the valve. It could simply be the seal holding it in place. The pushrod does worry me some, but have seen dozens of pushrods bent due to rocker failure, over revving, or broken springs.
make sure to kick someone in the nads for driving your truck with damage like that though
i'll bet that piston would still have a long life just like that!
Just kinda curious,What kinda plugs do you have in it?
Which dealership did you take it to?
