Cleaned up my pistons
ramv10
Houston,TX
I'm in the process of doing a NA build (heads & cam). Still have not received them, but heres where i'm at. Decided to clean up the carbon build up from my pistons.
All the pistons were like the left one (31000 miles)
what cam ,what heads ???/ inquiring minds want to know
Just a note on lifters / just make sure u put the lifters with hole up / am carbon on pistons build compression / compression make hp / an with that many miles u should put rings an bearings in it / would be more power gain
An make sure u degree the cam In / I went thru 2 custom grind before getting that was right
If you remove your knock sensors to get the bugs out from under and around your coil packs, make sure you retorque them with an inch-pound torque wrench. They are pretty touchy and like to be pressing into the block with just the right amount of pressure to work properly..
Anyone know what that cone looking thing is for, inside belanger headers?
