ramv10
i could of grinded the bump down some more, but felt it would make no difference
Slowly coming together
If he doesn't grind further into the ports is it still an improvement over stock?
Short video of my striker build first start up. There was a little oil on the header causing the smoke.
Ram srt 10 striker build first start up. - YouTube
Mmmmm....Strykers
Look forward to hearing it in person soon :burnout:
Short video of my striker build first start up. There was a little oil on the header causing the smoke.![]()
I have STRIKER ,you never say that to me lol :thefinger:
Bought the heads and cam from ronnie, so thanks for all the help. I did 3/4 turn on the rockers and went with slow bleed lifters. I went ahead and got my tune from torrie and installed it before i fired it up. Now i hope torrie comes back to houston so i can get it tuned properly. I'm pretty much done with the engine, still have to finish fabing up my exhaust. It will be a couple more weeks until i have it on a dyno. Will post results.
damn I did not know you were in h-town ,,i did a full turn on my slow bleed lifters ,after you get them pumped up you should recheck them ,i had to on both my trucks after i did cam and slow bleeds ,
What head gaskets did you use ?
oem gold head gaskets. I'm around 10.5 (+/-) CR. My heads were cut down a little to give me a 70cc chamber.
oem gold head gaskets. I'm around 10.5 (+/-) CR. My heads were cut down a little to give me a 70cc camber.
