Is this the egr valve and if so can it be removed without affecting the way the truck runs? It's connected to the intake and the canister under the truck. I'm assuming that all that can be removed but guess that a check engine light will come on. Is there a way to shut off the check engine light?
There was no pic attached, however if it is the EGR valve I'm sure it can be removed and based on other conversations happening in other threads, anything can be tuned out to keep a warning light from triggering.![]()
I edited it and attached one. It's showing up when I open the thread
That looks like part of the evap system.
Has anyone taken this whole system out?
I did
Dom
Undefeated on the Internet
That's the purge solenoid, it also can not be turned or hung upside down or it will cause a check engine light. Your evap system can be removed if you don't want it and don't have to worry about passing smog
Mine has disappeared
You can remove everything underneath but I left the Leak Detection Pump/Purge Solenoid (in your picture) plugged in to avoids Check Engine and tucked it away hidden. Very rare it'll come on on initial start maybe every 200 cycles ( months of driving) and I simply erase with SCT in 3 seconds and good for another month or two.
What about the canister underneath? What do you do with the connection where the wire harness plugs into that?
Canister gone, zip tied connector out of way![]()
Ok Mr I already did this! Lol! The PVC lines the go to the fuel tank... Do you cap those? If so where did you cap them?
No sir, let em breathe or you can't pump gas in the tank ;-)
Tank has to be vented and the purge canister took care of that. Now the atmosphere does ;-)
Damn, you treed me![]()
What is there to gain by removing all of the evap
