ARRESTmeRed04
Yea here's a pic
Nice, 4v heads too, with a blower mounted that far forward it might just fit on a 10
Yea here's a pic
Unless your looking for big power I'd stick with the paxton and try to find a dedicated drive setup for it.
They are 2v heads but with real nice valve covers
Ahh the shiny in the middle cornfused me![]()
Im running a 7" crank pulley and the rest are stock and 8PSI boost,I have the Blown Away blower brackets that are almost twice as thick as the stock Paxton brackets and theres an adjustable belt tensioner (that doesnt do much,being that its slot to tighten isnt on the proper angle,the pulley will push the belts together and touch before the end of the slot)
I keep throwing belts,Ive tried a bunch of different belts and they all get eaten up and eventually tossed off,wrecked 6 belts last summer,its when im torqued up and the truck moves sideways as I let off is when it throws it off and eats it up!![]()
Yeah I would like to find someone to make me a cog pulley for the crank and the blower:rock:
I have the JTSVP Billet aluminum overdrive pulley along with the factory Paxton pulley. I haven't had a chance to run the motor yet as I still need to put the motor back in the truck when I get back. So I'm not sure if it will slip, plus I wanted to run a smaller Paxton pulley to increase boost.
I emailed a guy about that says he has made a few cogged set ups for paxtons so I'll keep you posted
Those are the pullies I'm running now and they slip, cog belt system I'm sure will resolve all my belt issues.
I work at Southern Hotrod in Louisiana. I recently picked up a 04 SRT10 equipped with the Roe setup. We are known for big blowers hanging out the hood on late model Mopars. I've got a 6-71 BDS and a 8.3L Whipple at the shop now and it's not going to fit on a Ram SRT10 without major modification and fabrication. If someone could get that setup to work we could... I'm going to really look into this. Also,...
How much could I get for a low mileage Roe setup?
How much is the Procharger setup and what blower are they using on a stock 8.3L engine?
6-71=411 cubic inches, roe(whipple/lyshlom)=3.3/3.4L or 207 cubic inches, so yeah about half the size but I think they spin way faster
Saw yalls 300 in mopar now this month, totally badass. I think the last roe setup I remember seeing sell was around 5500 bucks. You should post up more yalls knowledge with superchargers would be very welcome here, the roe just never really lived up expectations(in my opinion) get with Justin at JMB for any procharger questions he is the one that makes the kits.
Would it help to treat the pulleys with Carbonite, which is a rough coating used to increase belt traction. Since the jtsvp pulley is 8 rib does anyone already offer a 10 rib pully for the crank? Also for the guys running the procharger cogged belt set up-How's the clearance of radiator fan set up? Did you have to switch to the electric fan set up?
Yes to run a cog set up you have to run electric fan assembly.
Stop posting and install your ProCharger bra! Many inquiring minds want to see this kit on stock internals! kthnxbye
