You pulled yours and sent it in and they are already done?! Still doing the big bore sleeves?
Yep re-sleeved, I paid up front before I pulled the first bolt out of mine. Money talks, and I let them use their preferred parts(piston and rods brand) and they have a good working relationship with callies and je. Custom pistons only took two weeks. I know they hate when someone buy some rotating assembly of the web.You pulled yours and sent it in and they are already done?! Still doing the big bore sleeves?
close i think the exact #'s are 4.123 x 4.006. I want to leave rrom to bore next time I rebuild. I will only be gaining 25-30 ci and about the same in hp. Maybe 550rwhp with the cam and stuff... Not exactly good bang for your buck, but the motor should last.Wow that was quick, what bore did you end up with 4.125"?
Thats why I did the smallest bore I can, rebuild once I get tired of this power level. Some nice custom Gen4 heads and intake w/ coil on plug would be next. I just need some winning power ball #'s lolUntil you decide to do the heads later, with the larger bore you could stuff a giant set of valves in the heads:rock:
One of these days I'll win the lotto, but I guess I need to start playing to increase my chances
Nice, how much more work you plan to do to the engine bay before starting to put it back together?
Less closer to 10:1, not exactly sure till I have the heads, waiting for valve spring locatersYou around 10.5:1? Or more?
Wow that's an ambitious time table
I LOVE THREADS LIKE THIS!!! Although it makes me jealous lol! I'm sorry if I missed it but how much are you planning on spraying?
sweet:rock::rock::rock:
question, $1300 for push tubes??? i did not know that gold was good for engine parts![]()
Oooooo.... Cam specs???400ish
1300 for cam, springs, seals... jmb justins kit he sells.
