BUMPSTEER KIT PREORDER LIST
Yes it works the same way just a few extra parts. Although harder to get right because you are going from an upward angle to flat so measurements will be off. I would highly recommend a alignment after install because of angle change won't be like just changing out tie rod. Hope this helps
Oh yeah gonna get an alignment anyway. Just for the install I can usually eyeball it pretty close.
[ame=http://www.youtube.com/watch?v=-vIjtvJANdA&list=UU1s7RduCOAjX6LdOjuBNXcA]DODGE RAM BUMPSTEER KIT FROM JTS VENOM PERFORMANCE BY RAZORS EDGE MOTORSPORTS - YouTube[/ame]
video sux, but gives you an idea
:rock::rock::rock::rock:
NOTICE
for everyone, there is no jam nut needed on the bumpsteer kit, this coming from paul at Razors Edge.
once the inner tie rod is tightened up against the aluminum adjuster, the outter hiem joint cannot move , in no possible way.
This was done after installing two kits that the extra adjustment would be needed for those with 2/3 or more lowering kits
if you must have the nutt those can be had
since we got multilple emails on the jam nutt we will include it with the next orders
we have already 20 more of the adjusters and kits already
the sway bar links are 95% done also
NOTICE
:rock::rock::rock:the sway bar links are 95% done also:rock::rock::rock:
thanks for the info.
then a dab of lock-tite be a good idea???
sway bar links & then then front end will be complete & like new:rock::rock::rock::driver::driver::driver:
thanks again:rock:
thanks again:rock:
to be able to get the most out of the kit, the best way is to run the heim joint all the way in, then use the inner tie rod adjuster to set the toe
You could use blue Loctite but remember if it ever needs adjusting an alignment tech may curse you;)
forgot the inner tie rod is the adjuster.
so no prob:rock:
been cused before & i'm sure i'll be again:bootyshake::bootyshake::D life is good:musicus:
