gearing question. not 4.88's
In all seriousness I've been wondering the exact same thing!
Have you really dialed in any real good runs through the 1/4 with that much HP? If so what is your trap mph?
We totally overthink this gearing thing. The rule of thumb should be to match the tire size to the gear ratio, so that you are running through the traps at the top of 4th. Bigger HP trucks can run a bigger tire, and thus use a taller gear. The reason short gears don't work on the track is that they require a shift to 5th gear prior to crossing the line.
I might be able to help you out in a couple weeks. I plan to be around 825 - 850 whp. Suppose to be going to the dyno this week and the track this week or next. Currently the truck has 4.56 so I'll let you know how it goes. Depending on where I run out of gear I will be going back to the 4.10s or 3.73s
You are running a TH400, correct? What tire are you planning on using? How much RPM do you want to run?
Can the '04 rear with the 4.10 be swapped out with the '05-6 with 4.56's or is their more to it ?
Ut oh....will this make me look stupid ??
LOL! No. It's an inside joke. Often, the first thing a new guy will come on here and ask is questions regarding gear swaps. When that happens, I sometimes bump a dozen or so old threads, to encourage them to use the search function. In your case, I think asking a gear swap related question in an active thread about gear swaps makes sense.
Oh, and to answer your question directly, yes. You can install shorter gears in your factory 4.10 housing. The consensus is to call Devin at Unitrax (http://gounitrax.com), and he will get you everything you need.
M&H 32 X12 slick and I'll be shifting at 5800 RPM when the nitrous turns off. I'll run it out to 6000 without nitrous
You shouldn't need a taller gear. 5800RPM, with 4.10's, and a 16" tire radius, will get you 134mph through the traps. That's fast enough to run low 10's.
Caveman is known for bumping old threads of the same question asked over and over, don't mind him...
Oh, and to answer your question directly, yes. You can install shorter gears in your factory 4.10 housing. The consensus is to call Devin at Unitrax (Unitrax • Differential and driveline parts and service. Ratio Changes & Overdrives. Axle Shafts. Using parts from the most reliable companies in the drivetrain industry: Dana Spicer, American Axle, US Gear, Timken, Gear Vendors, OS Giken, Autotech, F), and he will get you everything you need.
See, he even admits to it :D
Let me rephrase my question ; it seems at times the grass is greener and the 4.10 guys want 4.56's and peeps making more power wanna go the other way....sooo if was just an easy swap, could someone potentially just find another member with the different ratio and it would be easy peasy to switch em ??
The whole rear that is ....
