Thanks, my boy Patrick has always come thru for me. Actually have an order in place. I'll tag it on.ViperTruck2933 said:Several of the vendors here can get OEM gasket sets. Try Dragon, JMBJustin or Boomer.
No Problem, Bro. Let us know how you like the cam. :rock:Bone said:Thanks, my boy Patrick has always come thru for me. Actually have an order in place. I'll tag it on.
Bone said:Where did you get the gasket kit?
Does Boomer or any of the vendors have the cam before I get it at Summit? However, Summit is up the street from me too.
mmmmtorque said:There have been no issues with valve, piston clearances or spring pinch.
I thought the Mopar Cam gets 6-8HP and the Comp Cam around 25HP?:dontknow:DC Performance said:The Mopar Cam works better than the Comp Cam, more intake duration. Both are improvements over stock. The most important thing is getting the intake centerline correct.
Please explain this comment? 6-8 hp is better than 25 hp???:dontknow:DC Performance said:The Mopar Cam works better than the Comp Cam, more intake duration. Both are improvements over stock. The most important thing is getting the intake centerline correct.
HaulinAsp said:Please explain this comment? 6-8 hp is better than 25 hp???:dontknow:
Silverback said:Two ways of looking at it. Claimed HP vs actual HP gained. Or it could be related to usable HP. Lot's of dyno queens out there that can't get out of their own way. You can actually show a HP gain on the dyno and be slower on the track.
REMOVAL
1 - CAMSHAFT
2 - THRUST PLATE
3 - BOLT(S)
Perform the fuel pressure relief procedure (Refer to 14 - FUEL SYSTEM/FUEL DELIVERY - STANDARD PROCEDURE).
Disconnect the negative battery cable.
Raise and support the vehicle.
Remove the front engine shield.
Drain the cooling system
Drain the power steering fluid.
Remove the oil pan (Refer to 9 - ENGINE/LUBRICATION/OIL PAN - REMOVAL).
Lower the vehicle.
Remove the radiator and radiator fan assembly (Refer to 7 - COOLING/ENGINE/RADIATOR - REMOVAL).
Remove intake manifold (Refer to 9 - ENGINE/MANIFOLDS/INTAKE MANIFOLD - REMOVAL).
Remove cylinder head covers (Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - REMOVAL).
Remove timing chain cover (Refer to 9 - ENGINE/VALVE TIMING/TIMING CHAIN COVER - REMOVAL).
Remove rocker arm assemblies.
NOTE: Identify each push rod to be replaced in its original location.
Remove push rods.
Remove cylinder heads (Refer to 9 - ENGINE/CYLINDER HEAD - REMOVAL).
Remove hydraulic tappets (Refer to 9 - ENGINE/ENGINE BLOCK/HYDRAULIC TAPPETS - REMOVAL).
Remove timing chain and camshaft sprocket (Refer to 9 - ENGINE/VALVE TIMING/TIMING CHAIN AND SPROCKETS - REMOVAL).
Remove camshaft thrust plate (2) (Camshaft and Thrust Plate).
Slowly remove camshaft (1). Use care not to damage camshaft bearing surfaces with the cam lobes(Camshaft and Thrust Plate).
Stinker said:Bone per Gary , you should be able to remove the rocker arms, and allthe garbage up front , spin the cam and push all the lifters up in the galley and remove and replace the cam.
And Bone It would be advisable to get a cam cut specifically for the blower or FI application. These cams work well, but as in a turbo truck you need tons of exhaust, as well a SC"r needs a specific grind.
Not saying it willnot work , Blakes is working fine, but, you get better performance by talking with a cam grinder about your specific application.
I suggest you call comp cams and talk with them on this in theri tech department, they will be real helpful and be able to explain it tons better.
Bone said:Thanks. Been trying to....their phone is busy. People must have gotten mod money over the holidays!
Another question: Anyone been able to swap out their pistons without pulling the engine?
I don't think I can fit 69 Playboy bunnies in the truck, but I am willing to try.dragon said:cool man just want to make sure you get what you want in that beast.
Yeah, I'm easy on the phone, especially 976-BABE.Stinker said:Sweet Bone aint ya glad ya called?LOLOL
Bone said:I don't think I can fit 69 Playboy bunnies in the truck, but I am willing to try.
