Arska2
EU Moderator
crowsfoot is the tip of the day!
sooo....., crowsfoot is better than cameltoe, right ? :rofl:
Everything goes better with Jack! That's my motto
You should try the honey jack snakebite recipe i posted!
Good stuff
So about the lines...
Drain the reservoir
Start at the bottom with the rack.
Bring an oil tray with you down there and some rags.
Disconnect the hose from the rack
After you drain the ps fluid from the old hose, spin the fan by hand for a minute or so and it'll pump out more fluid
Then disconnect the other side of the hose from the fan.
Put your fittings in and tighten, then put the new hose on.
If you don't have a crowsfoot, stop here till you get one.
Pop open the hard line retainers with a screwdriver on the pump side hose.
Remove the pump side fitting from the fan.
Mine was REALLY on there, so i broke out the propane torch and VERY CAREFULLY heated it up, trying as hard as possible to not cook the fan shroud or the belt. Its do-able. After that it broke loose with the help of a crowsfoot, an extension, and a breaker bar. (There will be oil oozing out of this one)
Now go topside and use the crowsfoot to take off the fitting from the pump.
Again, mine wasn't going anywhere, so i broke out the torch. Heat this one with a few seconds on, then try it. Keep going till it breaks loose...don't melt you reservoir obviously.
After its off, have fun getting the line out without spilling fluid all over the place
Put the new fitting in with a socket and a u-joint on an extension (i used a 1/2 inch drive, deep enough for the fitting, but still cleared ok. I doubt a deep socket would fit in there)
Make sure the plunger and spring are still in the pump after you take the old fitting out, otherwise the system won't purge later.
It's pretty easy. Took me only a couple hours by myself.
Modelo sound good? Or are you tired of my paisa beer?![]()
The power steering pressure hose was seeping on my truck. Right where the rubber hose is crimped onto the hard line. Tied a piece of oil absorbing mat around it with some zip ties. Seen my friend do it on his old V10 (cast iron) truck. It worked well keeping everything from being oily mess. When the engine was redone I put on a line kit. Cost was way cheeper than the one new factory line.
I switched to 805
Just got word from Justin, box of goodies coming my way!
Also Tony hooked me up with Joanne so i have a shiny new shifter ball coming too
Now i need to find the motivation to get out there and handle the under drive pulley install and finish the polish on my intake manifold.
I found the UDP to be pretty easy job, and I too used the hammer and wood. Ended up bending the outer lip of the pulley either by force or by drop, not sure which caused it. The PS lines looks more daunting to me based on the requisite tools that I'm sure I'm missing.
Hoping to do coils, wires, plugs during the winter (and the leaky PS lines). Need to order some parts first though.
