Gill
Member
- Joined
- Jul 14, 2020
- Messages
- 46
- Reaction score
- 21
I just re-read some of your info.
IF the cable is too tight it will delay the part-throttle shift then shift "harder than normal" when it finally does. If its too loose, line-pressure will drop and your shifts will slip and slide.
"The transmission is flaring, not slipping". Hmmmm- Actually the transmission IS slipping, it's the engine that's "flaring" during the shift because the transmission is no longer propelling the truck forward even under slight engine load.
So in normal driving the tranny is taking longer to shift into the next gear, and it is a rough gear change. Example is when taking off from a stop, 1st into 2nd takes until 3000 rpms and same for 2nd. 3rd and 4th are smooth. Now on the contrary, 1st gear under full throttle sticks whereas 2nd gear slips and goes into 3rd
