2005 QC Transmission Slipping
Discussion in 'General Discussion' started by Gill, Jul 15, 2020.
Car Parts
  1. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    So in normal driving the tranny is taking longer to shift into the next gear, and it is a rough gear change. Example is when taking off from a stop, 1st into 2nd takes until 3000 rpms and same for 2nd. 3rd and 4th are smooth. Now on the contrary, 1st gear under full throttle sticks whereas 2nd gear slips and goes into 3rd
  2. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    Sounds like your kickdown cable is adjusted too tight then.
    IF there are other problems (as mentioned), the cable adjustment won't fix worn out clutches or band.
    Hopefully though, the cable adjustment will return things to normal.
    Did you get a chance to check the fluid odor??
  3. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Just checked the fluids, smells normal as the one I tested at the shop earlier. Good sign of things. I will work on the cable and keep you updated on the progress
  4. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    That's good news.
    The cable adjustment can be quite touchy.
    Again, you want it to move AS SOON AS the throttle cable moves.
    Good luck!
  5. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    Loosen it right off then sneak up on the adjustment until the throttle and kickdown move together.
  6. AMS3
    AMS3 Well-Known Member
    1,066
    766
    Aug 8, 2019
    Savannah Ga
    What part of North Cali? I lived the first 17 years of my life in Calaveras county about 5 - 6 miles from Big Trees State Park.
  7. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    Giid morning Gill-
    One other item to check before considering spending money. There is an external spring on the transmission that holds the kickdown lever forward. Make sure it is still hooked up.
    Cheers
  8. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    Good (not Giid)
  9. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Attached is a video, looks like you were right the kickdown cable isn't moving
  10. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Manteca, close to Stockton. About an hours drive from Calaveras County
    AMS3 likes this.
  11. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    That's the cable for your cruise control.
    The kickdown cable is the lowest one.
  12. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Ok, adjusted that cable. Marked where it was and brought it in about quarter inch, clipped it back up.
    Huge difference in shifting, I'd say 1st to 2nd now shifting 1200-1300 RPMs, 2nd shifting to 3rd around 1900. Drove it around the block normally and then took to the highway. Man oh man, the cable adjustment really worked. Hasn't slipped from 2nd yet, took a couple videos:
  13. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    Hey, that's great to hear and free!
    IF it is not allowing wide open throttle upshifts, the cable is likely a little too tight.
    You are likely finding out how touchy that adjustment is. :)
  14. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    I'm going to drive around a couple more days and see how it responds. Might dial back just a bit, but so far so good. Resized_20200716_123309.jpeg Resized_20200716_123327.jpeg
    VIPR PWR, Srt10650 and Kiwi SRT10 like this.
  15. AMS3
    1,066
    766
    Aug 8, 2019
    Savannah Ga
    My folks live in Mt. Ranch, ever heard of it? I haven't been home since 1999, need to get out that way. After the lockdown of course. Stay safe my friend, and hope you get the tranny issue fixed soon. These trucks are a blast to drive :) My truck is identical in color as yours. Only differences are I have the bed mounted spoiler, no hard cover, and my front lower grill is different. Oh, and my paint job is horrible due to the sun. Your's looks pristine, must have been kept under a carport or something.
  16. rottenronnie
    4,177
    2,148
    Jul 4, 2006
    Calgary, Alberta
    Nice looking truck you have there Gill!
    Be patient with that kickdown adjustment, there is a sweet spot that will allow it to shift at wide open throttle (without lifting your foot) and provide solid part-throttle/light-throttle shifting as well.
    You will find it. :)
    Literally, 1/8" can make the difference.
    Have fun with your rig.
    Ronnie
    AMS3 likes this.
  17. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Yes, I went hiking around there 3 weeks back. Nice country out there, cool and surrounded by the woods.
    This was the original owner I purchased from, had it garaged with a cover. Interior is spot on too. I paid 25, little pricey but more affordable than the viper :D. This is in addition to my widebody hellcat, so makes for a nice garage.
    AMS3 likes this.
  18. Gill
    Gill Member
    46
    21
    Jul 14, 2020
    Thank you for the help, I honestly wasn't sure if I'd get a reply but really happy from the support on here. I was looking up posts from early 2000's thinking that's all we could get. I will tinker with it a little at a time, working 6 days this week so need the snooze first. I really appreciate that quick help, got this thing working. Now to show the boys at work tonight :cool:
    AMS3 and Kiwi SRT10 like this.
  19. Kiwi SRT10
    Kiwi SRT10 Well-Known Member Supporting Member
    1,012
    1,119
    Dec 16, 2019
    New Zealand
    Nice truck Gill Welcome aboard. This is a good place to get info and share fun stuff and brag pics etc
    You need more exhausts lol and the steering wheels on the wrong sideo_O:eek:
    AMS3 and rottenronnie like this.
  20. Kiwi SRT10
    1,012
    1,119
    Dec 16, 2019
    New Zealand
    Spent quite a bit of time in Cal back in 01, 02 we were driving trucks. We used to drop wine barrels off in Northern Cal, Manteca, Napa, then pick up produce, mainly Salinas area
    Great memories, long time ago now
    AMS3 likes this.
