Hello SRT-10 Fans.
Just a few Sunday morning thoughts on a Monday…
The pistons on the SRT-10 aren’t great and are indeed mechanically stressed more when accelerating at w.o.t. in a heavier vehicle like a truck and even more stressed with sticky rear drag tires during a 1/8th or ¼ mile pass.
The O.E.M. Piston Ring-Lands have their design to pass emissions. Low rings/ring-lands “hide” unburned hydrocarbons and fail the sniff-test so they aren’t designed that way on emission engines. If any engine doesn’t pass emissions (VW diesel excluded, well, until they got caught), they can’t be mass-produced and sold. BUT higher ring-lands can be more prone to failure.
THE NUMBER ONE KILLER OF ANY PISTON IN A GASOLINE ENGINE IS DETONATION. Even a mildly aggressive tune will crack a ring-land in a stock 8.3L as they are arguably a bit more prone to this type of failure than other performance engines running around. This is no doubt why they are victims of the blanket statement “The pistons are weak”. Keep in mind detonation isn’t just from a tune with too much advance (ignition timing) but it is a big contributor. Low octane fuel has the same effect.
If exposed to even brief detonation, a piston crack MAY hang on for several miles or it may fail immediately.
A number of years ago I believed a buddy could properly tune my 8.3 and the engine almost made it to the 1000- foot mark before it failed on the very first ¼ mile pass after the tune was installed. #8 popped but didn’t jam in the cylinder and take the block out. So, after the tune was installed, my engine lasted less than ¼ mile.
And here is where the “at what mileage will these engines fail?” question comes in. The short answer is immediately with a bad tune but will last a normal duration with decent maintenance and a proper tune (or no tune).
QCs are horribly lame without a PROPER tune and (to me) was worth “rolling the dice”. A 15.2 second E.T. (at our altitude, untuned) just wasn't nearly good enough. I was an early adopter of cross-shipping a brand new ECU to Dan Craigin and Chris Jensen at DC Performance when my truck was new in exchange for another new one with a tune. This was prior to using hand-held OBD II Controllers to get performance tunes in and out. Both Dan and Chris have plenty of experience with Viper engines and do/did R&D for other companies for products installed on Viper engines. These guys know their craft.
Keep in mind that preignition/detonation will also (literally) hammer a forged piston into submission as the ring-lands will often compress and prevent the rings from doing their job. They don’t crack and fly apart like a cast piston might, but eventually the engine will have to be pulled apart if the detonation (whatever is causing it), is left unchecked.
Even a “Forged” engine isn’t indestructible.
Enjoy your trucks and IF something goes south, make a decision then.
