SrtBrad said:Darrin I'm glad you took my advise on starting this thread.
I'm sure any reasonable person like Darrin would want advise from several members,friends, and family before taking any further action. Hopefully there is a reasonable outcome to this situation.
Hopefully Pirateman steps up and addresses this issue and makes it right. In the mean time is there any members/builders/vendors here that would be willing to take the engine apart as a neutral party to address the reason for failure?
Ok, now what exactly is the failure? so far the engine has not failed, the problem is a vibration.Darrin can crank and drive the truck as it sits now, jsut not above 150mph according to what he told me, anything above 155mph an the vibration got scary.
now if the vibration is comming from the engine it should get progressivly worse with rpms, so in any gear it should vibrate, or at least at a certain rpm in any gear, and most likley come apart, so far the engine has not failed, the vibration could be comming from the clutch, flywheel, driveshaft, tranny, bent axle, axle tubes, any number of things,
more things actually need to be checked before a complete teardown takes place.
