Ironhead said:
ok someone explain the duel set up ,,,site says it operates as a standard srt-4 gauge ,,,,what is a standard srt-4 gauge
The Interceptor is capable of displaying the following parameters, two at a time (8 using cyclic scan), at an adjustable rate of up
to approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will
display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, the Interceptor will recognize this
and make it available for display
The Interceptor gauge is 52mm (2 1/16") in diameter and will fit in all standard gauge pods of this size. A 5' cable is included with
appropriate OBD2 connector. A splitter cable is included with the dual Interceptor units.
A function menu is available by pushing both buttons simultaneously. One menu option allows you to enter a record mode. Once
selected, the Interceptor will return to normal scan mode, but will start recording the displayed data automatically when the throttle
exceeds 60%. Approximately 60 seconds of data will be stored. Returning to the menu screen, you can choose to replay the stored
data on the Interceptor display.
The gauge displays 2 parameters at a time, but can be programmed to cycle through up to 8 parameters during a user determined
period of time. This way you can monitor several items without taking any other actions.
High intensity LEDs can be used as shift lights or warning lights to indicate when a selected parameter exceeds an entered
threshold. Due to the gauges extremely fast update rate, this light is very accurate and easy to set. Once you try it you'll find you
can't live without it!
Another menu option offers the ability to swap the foreground and backround colors of the display. Using this feature, for example,
the gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive
image). Not only can this be visually appealing but beneficial in changing lighting conditions. Positive images are easier to read in
bright sunlight, negative at night.
The Interceptor's scan rate can also be adjusted through a menu function.
DTC's (Diagnostic Trouble Codes) can be accessed and cleared via menu options.This essential feature will help the gauge to pay
for itself the first time the check engine light comes on. Those that have modified their vehicle will find this very handy when a
sensor, vacuum line, etc. has been inadvertently left disconnected, or something was just not put back together properly. Click
here for a list of SRT-4 diagnostic trouble code descriptions.
The two analog inputs can be configured through menu choices. A linear conversion can be entered so that an analog signal
connected to the gauge can be read in appropriate units. These inputs are handy for pressure signals such as those from MAP
and oil pressure sensors, analog outputs from Air/Fuel ratio kits, etc. These signal can then be read and recorded along side the
other parameters obtained on the vehicle's bus.
The gauge has bi-directional controls allowing for manaul control of the low and high speed fans.
Last but not least, the Interceptor will measure 0-60 times, as well as 1/8 and 1/4 mile time and speeds. This is accomplished
through a simple menu selection.
Installation is accomplished by simply plugging the supplied connector into the OBD2 port below the steering wheel. Literally
plug-and-play!
Warranty
Aeroforce Technology warrants this product and its accessories against defects in material and workmanship for a period of 1 year from
the date of purchase.
