By the way, the last 4 numbers of the metric part number is the length of the belt in millimeters.
blackviper said:By the way, the last 4 numbers of the metric part number is the length of the belt in millimeters.
WOT said:A couple of points to ponder:
It is my experience that if you bend a rod on a nitrous hit it is due to too much timing. Nitrous speeds up combustion so much that you have an extreme pressure rise while the piston is still traveling up on the compression stroke. It acts like hydro-locking the motor. You compensate for this by retarding the timing when the nitrous comes on. Are you guys doing anthing to retard the timing when the nitrous hits?
1sicponi said:Bone, I have been pulling engines apart since I was 14. First was a Briggs and straton for a go cart. Shaved the heads with a file to get more compression. What I saw in those picks scared the shit out of me. The plug wires go under the intake? I'd rather try and hide shit like Orange county ny choppers do. Thanks for the picks. Great sight.
Think I'll just look at how pretty and clean it looks under the hood. And to think I almost bought a ROE S/C and was going to install it myself. bobbymac
Bone said:My timing was very conservative.
I have a SC flash with a VEC 3 on top of it for timing control.
2 stages colder iridium plugs.
3 knock sensors (2 stock and 1 MSD).
Higher octane fuel and toluene mix was used.
Lower compression Diamond pistons were used.
I had stock rods using a SC and NOS. Way too much HP for stock rods.
blackviper said:Bone, if you're in between 2 sizes, try calling Napa Auto Parts. They have a larger idler pulley. I can get you the part number if you need it.
I used 2 degrees/50 shot and added 1 more for safety at the end. Already had a reduced SC timing from Sean.WOT said:Sounds like you have your motor set up correctly, but you just need stronger parts!
Oh, and just to clarify, usually you retard the timing not only for detonation resistance, but to insure that peak cylinder pressure is actually occurring after top dead center. Since the nitrous speeds up the burn, you end up losing power with too much advance even though you might not have any detonation whatsoever. But the pressure spike can cause seriously ludicrous cylinder pressures and do things such as bend rods and blow out head gaskets, etc. Typically you would want to retard 1-1.5 degrees per 50 hp shot of nitrous. So, for a 250 shot you would want to retard up to 8 degrees more than you would for just the SC. So if you are retarding 5 degrees for the boost, then you retard another 8 degrees or so for the 250 shot of nitrous.
Either way, it sounds like stronger rods are in your future. Best of luck to you.
Bone said:Thanks. I haven't gotten that far yet. The larger crank pulley is being redone by David Weaver, offset is a little off-line.
belgiumbarry said:you're serious about the rebuild he ? :dontknow:
Bone said:LOL, I have no other choice! :nurse:
Not a problem. Now shipping an engine would be interesting.belgiumbarry said:haha ! :rock: good work... maybe i ever ask you to make me a copy ...
Bone said:Not a problem. Now shipping an engine would be interesting.
