belgiumbarry said:don't they float :dontknow: :dontknow: :dontknow:
If you get a good ring seal and if they don't rust out before it arrives...then it will float. Remember when we would talk about "valve float"???
Prof said:If you get a good ring seal and if they don't rust out before it arrives...then it will float. Remember when we would talk about "valve float"???
Bone said:Improved Crank pulley.
Thanks Eric! :rock:
see posts 81, 113, and 116.perk_1405 said:improved:dontknow:
nutin really, been putting it together. Had to give Dan a break during Easter.eddie102870 said:whatcha waitin on now?
he deserves it, bro. thats gonna be a bass azzzz motor when its done. i know your ready to ride again.Bone said:nutin really, been putting it together. Had to give Dan a break during Easter.
I am not allowed to post that info.walenator said:What kind of main caps are you using?
I finally read the entire thread and no'one mentioned the head face being so clean . My guess is that the cylinder got "wet" which caused a hydrolic effect to bend the rod . the cylinder recieved some fluid for a short time before hydrolicing the rod ,which cleaned the head face. until it finally leaked enough fluid into the chamber to bend the rod. The question should be what leaked in and why? before attempting any more boost . and/or NOS ! even thoughs crower rods will not stay straight with fluid in the chamber.Hucksrt10 said:Here is the interesting part. Look at the head wall of number 7, cleaner than the rest. We have been debating this for awhile now. Remember, I have/had a Roe SC on top of the heads with Sean's baffle/IM/diffuser plate on top of it for a distrubted air flow. Also, did not blow a head gasket, it was fine.
WHUT?????:dontknow:[/quote]KRAZYSRT10 said:I finally read the entire thread and no'one mentioned the head face being so clean . My guess is that the cylinder got "wet" which caused a hydrolic effect to bend the rod . the cylinder recieved some fluid for a short time before hydrolicing the rod ,which cleaned the head face. until it finally leaked enough fluid into the chamber to bend the rod. The question should be what leaked in and why? before attempting any more boost . and/or NOS ! even thoughs crower rods will not stay straight with fluid in the chamber.
Is there any reason to believe that the heads would,due to all that cylinder pressure,"float" and could the blower over pressure the coolant system?and allow "maybe some leakage past the head gasket?
Just a thought .
He's thinking water/coolant got into the cylinder thru the heads (gasket) possibly.Bone said:WHUT?????:dontknow:
