Clutch question??
kyle's srt10
Arkansas
What would make the RPM's not fall off when clutch is pushed in while driving and changing gears?:dontknow: It works fine goes in/out of gear no problems. The truck has a spec clutch and viper master/slave
Never had this problem before just thought I ask to make it more simple to get it fixed:D
I actually wondered if the throttle cable might be hanging:dontknow:
Mine did that for two years, it drove me nuts. I tried every fix out there and nothing worked, until I had Chris Jensen tune the TPS. I haven't had a problem since.:):)
Mine started doing it when I changed the TB. Chris datalogged the truck and fixed the issue.
Yes, the truck has sit quite a bit in the last year for sure.
So should I start by replacing the TPS or is there something I can clean up first and try?
I'll give the TPS a shot tomorrow and see if that solves the problem.:rock:
Is it an aftermarket throttle body? And cleaning the IAT sensor may help also.
I've been good man, how about you? Glad to see your in another 10! I have 2 coffee table blocks now:eek: and one engine in the truck and one apart that ill hopefully have time to finish and mount those turbos on one day!
I've ran 2 different aftermarket tb's and both would sometimes idle high when I clutched it. I think there was a thread about it, and how someone had traced it down to the blades sticking/dragging. If I remember right they sanded a bit off the blade to fix it. It's been awhile back ill see if I can find the thread.
