Stinker said:side by side, intake comparison, valve comparison , a set of the rockers
Those are so sweet looking :rock:
What you going to do, put them on your sled for PCB? :dontknow:
they like my block have been sitting for two years now:argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh:Da1Chief said:Those are so sweet looking :rock:
It really depends on the cam you are using...The more overlap, the more the cylinder will blow-down and fail to produce pressure until it is up to speed and into the cam's operating range...something that isn't going to happen at cranking speed...Ironhead said:what would be the compession on them with 10.1 ,,,i mean the reading in psi on a compression gauge ,,?????
damn i need to get to work ,,boring in this plant ,,,nothing really to do but sit and wait for a break down
ViperPunk said:hey ronnie since you work in a shop building motors and such why don't you slide me your cam and just get another for yourself that would be easy for you right :marchmellow: seriously though your sig says mild custom roller wanna elaborate on your cam a bit for educational purposes? i assume by mild its a street/strip kinda deal
how do you like it? are you gonna build another somedayrottenronnie said:It was an experimental one-off and is based on the Viper Coupe cam. It was ground for torque and also for my "educational purposes".
A wide l.s.a. and .600" lift...
ViperPunk said:how do you like it? are you gonna build another someday
ViperPunk said:the main thing for me is obviously to pick up some good hp and tq numbers but i want a pretty hard idle for a street/strip setup
ya im definitely gonna pp the heads, intake, exhaust manifolds, get a cam, and bump the compression for now then i will do stikers and long tubesrottenronnie said:You probably already know this, but there is not much power to be gained with a cam swap on these engines without head work or aftermarket heads...
my bad you meant how much power a cam could pick up with FI im sure ronnie knows that oneMcLuvin said:what about with forced induction?
actually qcs do have a camshaft....it would not run without it....JAYSSRT said:just wondering since we are talking about cams...I noticed they are only on RCs...i never seen a QC with a cam.:dontknow:
depends on what fi with a paxton leave the stock cam in there and do very lil headwork.....McLuvin said:what about with forced induction?
