Da1Chief said:Ok, trying to think this one out....
Obviously, I would want the truck tied down securly, but too much down pressure from the tie strap would be bad. That suggests that the direction of the tie straps should be more to the rear and front t cut down on the angle.
However, at a lower angle the tires would spin, which would be bad. This suggests that the tire pressure should be lower as to add better traction to the rollers.
The "Trick" would be figuring out what the ballance between the two are.
Is my thinking correct on this????
From the what has been said already Changing gears druing the Pull would give wrong/bad readings on Torque numbers.
I could very easy press the "Tow" button on the Shifter and let the truck change gears up to normal. How do I keep it from kicking into Over Drive when I floor it for the WOT Pull??
As I have a Quad Cab (Automatic Transmission) Does mean that I would also want them to prevent the truck from changing gears/kicking into Overdrive druing the Pull????
If my thinking is correct How would I accomplish this?
