maybe you need the timing retarded some this will increase the exhaust temps you can make the pipes glow red with enuff timing removed that should make the exhaust cleaner, maybe you need to ohm the wires going to the sensors ?
Torrie seems to think its some sort of physical issue, not tune related.
I loaded factory tune (whatever was loaded when I bought the truck) last October, I'm concerned it may have had a sct tune loaded before I bought it and thats the issue. Anyone think that could cause this?
Well I was going to suggest loading your stock tune before it was tuned, but if your saying it is a possibility that it might have already been tuned when you bought it then I dont know what to say anymore.
why dont you hook up someone elses truck for the Emission test and have the papers stamped on your vin / Name ????
Everything is possible with some Dollars, isnt it ?
I dont know if this has been answer but is it possible to swap pcm's with one of your buddies just to test and see if theres will go ready?
Is it possible that you have a messed up PCM that just doesn't go ready?
Andy, Can they reflash the PCM at the dealer? I think the PCM is bad or has dropped some code.
Haven't purposely tried it. Battery went completly dead last August, pulled it out for about a week then put an optima in.
I would assume the caps discharged over the time spent without a battery, but no I haven't deliberately discharged the caps.
If there is updated software they can reflash it. Have you tried a capacitive discharge on the PCM? You may have mentioned it before but I didn't re-read all of the posts.
How do you do this Andy?
