TREKER
Took the 10 out tonight for the weekend. Started fine, drove okay, but noticed that it was Bogging a little bit and sounded like it was hesitating. I gave it a little more gas to see if it would clear up but the engine light came on.
It was popping slot too, more than normal with the power sticks. I pulled over and shut it down for a few mins. I needed to get home, which was just around the corner. Started it up and same thing. Turned into my street and light gray smoke started pouring out and smelling like fuel. It was still running but sounded like the fuel wasn't igniting. Smelled like it too.
Got in driveway and popped the hood. Nothing leaking, nothing smoking. Truck seemed weak on power too. I don't have a way to check the codes so maybe someone can tell me how to get it to show on the dash.
I e thrown a code from time to time but never had a problem like this. Actually had something similar happen a few months ago too. Took it into dealer and they said I had a bad gasket on the valve cover leaking oil onto the plug on cyl #1. They changed the plug and the gasket. Was fine for a bit then this happens.
Anyone have any ideas? Could a bad injector do this or a bad coil pack. If gray smoke that smells like fuel comes out, what can it be? Temps good, oil pressure good, everything running fine until this.
Towing it in morning to dealer. Just want some advice and some things to look and ask for when she goes in.
Thanks
Thanks
