rottenronnie said:Jim has a flush as well as it is important to get ALL the water out of your system. He said a couple of gallons of flush will do the trick.
He said some guys fill the system with Evans itself and then dump it all out but that is pricier than it has to be.
Once the coolant is installed, it is there for good. No replacement required, ever. If you like, you can completely seal the cooling system off- take
the overflow tank off,etc.
Like I mentioned, I am just learning about this stuff myself and (so far) have ZERO actual experience with it.
I just posted to see if anyone did have experience with it. Sounds like we will all learn about it first hand....
It is the reduction of hot spots and detonation that intrigues me more than anything...that and the fact that water pits (badly) especially in systems with dissimilar metals and THAT is eventually what causes head gaskets to fail in engines where coolant isn't changed AT LEAST every few years.
Ron
OK,I mentioned just my rad and heater core is cause my block (complete engine)is bone dry right now
Yellow Venom -5gal
Yellow Fever#154 - 5 or 10 gal?
Rotten Ronnie -5 or 10 gal?
EXO -5 gal?
Any one else HuckSRT10?
