yellowfever#154
The Roe triple pass should have significant cooling reduction capacity. Sean was very successful in getting temps way down on racing vipers...my radiator is his prototype to try to do the same for our trucks...I have high expectations...but will not have data for a few months...but he has never let me down in the past...I am confident that this mod will reduce ambient engine temperatures by 25 or 30 degrees...
Prof, you need to add Justin's fan to this radiator. With a Flex-a-lite controller running the fan you I'm sure would see a huge difference.
I was able to control my temperature to as cold as the thermostat and not let it come up any higher than that. His fan truely works very well. It removes alot of strain from the power steering pump and you can get rid of two hydraulic lines as well. Less lines = less potential leaks. :rock:
