BlackMamba50
#10pistonkilla
Where can you get a new cam for the SRT?
DC Performance or Roe Racing
How much more would better rods and pistons weigh compared to stock ones? Would have to add weight to the crank for balance I would imagine? I would love to do a cam change but going that far apart, might as well forge it! Which gets expensive when considering how much use in this part of the world
adding pistons and rods does nothing for performance , basically they add strength
it will add some depending on what you do and what you go with , but bascially you are strengthining the amount of performance you can achieve,
I wouldnt want anyone that purchases pistons an rods from me to think they will add 100hp by just going this route.
now bump compression, coating the pistons, different rings so on, those make a difference.
the other day we looked into doing some lifter with guides on Mike Baabs engine, after looking into it, there is no real gains,
Jeff had a set of 8k lifters setting ther out of a spec engine, they were def nice, LOLOL but in our apps, or a normal app, changing certian things dont benifit us to be worth the while.
it
Are you serious???? your an acclaimed engine builder and you make a claim like this...
common now tony do some research before you spew forth info like this, especially when people on here take what you say for truth no matter what it is...
Our motor has an extremely heavy piston, a good aftermarket forged piston saves you about 100grams per piston x 10pistons 1kg of rotating mass off the piston, that will cause major increase in acceleration in your engine and you will get down the road much faster... This goes for the rod as well, and again take your rod weight savings plus piston weight savings your upwards of 1.5 to 2Kg... That does not sound like much but in your engine that is HUGE..
If you are using a cheep eagle piston or rod which is total crap.. yes you will see no difference in performance, but if you do some research on a good piston you will see huge differences in performance..
WOW Tony you shocked me on this one.. If I was getting a twin turbo or Turbo build by someone who gave me this info I would be running out that door so fast wow...
the difference rods an pistons make are very marginal at least, its all in the design of the build , but for someone to think they can jsut replace th e rods and pistons and get any substantial gains, is just not going to happen
Thats kinda uncalled for bud....Tony answered correctly...your simply added to it.....
he simply said that adding forged pistons and rods by itself doesn't ADD POWER...... It adds strength allowing you to make more power....ie. bumping compression, FI, nos.....Now you added something that he didn't mention.....weight savings...... which is a performance gain but isn't adding anything..... don't be a douch
If it gets you down the track quicker thats adding something.. If your building a dyno queen.. no it does nothing for you.. But if you building a real world car yes its huge..and on an engine our size its a major major component of a new engine build or a NA build...
and sorry I had to be a douch but when a builder is claiming things like this its absurd .. Now if he was a joe blow guy on the forum sure he would not know any better or should not need to .. But common this guy is doing 40k builds ... and then says its all in the design.. ... :dontknow::dontknow:
.. your twisting his words for your own satisfaction buddy
adding pistons and rods does nothing for performance ,.
just what am i twisting
