From what I'm gathering is when u put lighter pistons and rods in, your engine will pick up rpm quicker, but you would only see a benefit in the quicker rpm gain with some help like FI or spraying it.
Not true again, it benefits all motors regardless of induction type. It's really simple, like a torque converter, less rotating mass. Like an Aluminum Flywheel, Less rotating mass. Like Aluminum skinnys, less rotating mass. It all boils down to saving the weight on reciprocating parts in an assembly, whether motor, clutch, wheels, driveshafts etc.
And to Tony and Troy, it hasn't still been made clear that a piston swap, by itself, CAN PROVIDE A SUBSTANTIAL GAIN IN POWER BY USING A DOMED, CROWNED OR "POP-UP" STYLE PISTON!!!! You are changing the combustion chamber attributes and increasing cylinder pressure as RONNIE noted, which will result in MORE POWER! Now for FI and N2O engines you actually reduce cylinder pressure on the motor as the BLOWER,TURBO, OR N2O will increase CYLINDER PRESSURE in the engine when intorduced. These use dished pistons that actually have compression dropped to below factory standards. Again, as the Canadian has said, if you can control the Detonation Factor you can build alot of cylinder pressure and reap HP benefits and the forged pistons simply help stand the additional pressures and occasional detonation if it were to occur.
Perfect timing with regards to cylinder head combustion chamber, cam profile, compression ratio, and fueling all attribute to running a higher compression NA motor as well as FI engines. In other words just an incorrect tune itself can grenade an otherwise bulletproof engine.
Just my .02, and I never have built a Viper V10, but I did stay in a Holiday INN Express last night,:marchmellow:
I have built several blower engines as well as high compression NA engines in the past, however, and have a decent knowledge of an engines desires to be as efficient per C.I as possible. Some technilogy just hasn't evolved with our engines yet. Alot to be discovered though.
