Wastelands Warrior
Who needs a prius with gears like that.
Sent from my SPH-L520 using Tapatalk
Lol.
I went and looked at this one yesterday. It's as clean as a truck could be, like a brand new 2005 RC... only with WAY MORE POWER. If anyone here is interested in buying it let me know and I'll put you in touch with the seller.
http://www.youtube.com/watch?v=d5Yy63HQF58
Ronnie, here is the last head I wet flowed here in the shop. What do you think of it? Is it good? Bad? Why?
Thanks!
Very interesting, thanks! So, assuming good swirl, can you have too much CFM for an application?That is a popular LSx head as it comes from the maker. The wet flow is horrible. You can't see it in the pic but that port has a curved wing in the valve pocket. They put it there to reduce swirl, but in the process they cause air/fuel separation.
What you see is the head disassembled. It was tested in a normal flow test with the valves in. A mist of ink was sprayed into the port at maximum lift. The port converted it into liquid and did a poor job of distributing it around the head of the valve. The ink trails you see on the short side radius weren't even being allowed into the chamber.
I'll straighten out the wet flow problems, and also get a cfm gain in the process. You don't have to give up cfm to improve mixture quality on a wedge head.
ETA: A wedge intake port will swirl much harder on a running engine than on a flow bench. We wet flow on a flow bench to make sure we're in the ballpark, then study the carbon patterns in the chamber after it's run. Without swirl the air/fuel ratio will vary across the chamber. The intake will be the leanest, and the exhaust side the richest. We induce swirl to stir the mixture better and get a more complete burn. I'm a big fan of swirl. You would not want a wedge head that did not have it. You can adjust the intensity of it, and the geometry of it to get it the way you want it.
Nope. There is no such thing as too much airflow. You can have too much cross section though.
ETA: A good A to B example is NHRA Pro Stock Motorcycle. The 4 valve engines in the past ran cams with 10 degrees less duration than their 2 valve counterparts. The 4 valve heads flow better, and fill a cylinder quicker.
Thanks for the info Greg. Since you are allowing us to pick your brain I am going to take seconds. I understand the affects that creating a swirl have but is texturing or dimpling the chamber surface affective in these engines? I had heard that it aids in atomization but the last time I saw anything on it (20+ years ago) it was all based on carbureted motors. Thanks again for participating in a thread with some tangible info.
Greg, [rub on the lantern] for my third wish I would like to know what makes the Gen IV heads flow so much better than the earlier stock heads. Is it a raised intake runner? Bigger chambers? Better chamber shape?
I have seen the flow numbers on Trainman's set that you ported, I have had a set ported, and I have seen earlier heads' ported numbers and there seems to be a dramatic increase. What makes them have such a significant flow increase.
I couldn’t care less about being on or off of one of your lists.
this is the only thing that i took out of your post.
thank you for using this statement correctly
anyways - carry on.
side note: i need a passenger head and am considering a H/C build in lieu of a stock head replacement and FI alternative.
true story...
I really like the semi-oval intake ports over the rectangular ports, but we can't have everything.
Grammar nazi.this is the only thing that i took out of your post.
anyways - carry on.
Nobody cares, also a true story.
