ARRESTmeRed04
ya just need to do a clutch upgrade and master slave upgrade and your golden
Got yours back up and running again? What kinda torque did you end up making
After getting nowhere with the search bar, figured I would pose the question. Who has a good NA build? I may be deploying again soon and if I do I will be getting a few more goodies for my truck. Just curious who has done a respectable NA build, what they used, etc. I mean I know TB, heads, cams...but just curious what all works well together and what people have had luck with. Current power mods are: catless, magnaflow muffler and SCT by Torrie. If anybody could just suggest another member to talk to that would work as well. I am sure this covers several items that have been discussed an endless amount of times...just difficult to gather it all at once. Thanks all!
The Strikers and small cam I'm using work very well. I'm currently at 577/607 TQ. (Auto Trans.) with pump-gas, no additives.
I could add even more power to the engine by installing headers, porting the Strikers, installing a larger cam, adding more compression, doing intake manifold mods, installing a more aggressive tune, cats, etc., but my current combo should give you an idea what to expect for numbers if you go this route..
Ronnie
Im in the hunt for a good matching cam for my striker heads ,,i still want good drivability ,but i do want the best match for heads ,,im going with 10.5 to 1 wiseco coated pistons,, ,i was hoping striker would have a matching cam to go with heads ,,for best results ,, you mention small cam ,can you give specs on that cam ????
[email protected], .600 on a 114 would work well for building torque in a truck.
is that 228 on intake and 228 on exhaust ,,,and a stock cam is 114 also right ??
Eh Ronnie any word on the Striker heads being available soon. Or by spring 2012.![]()
Thanks Ron i know you'll let us know as soon as you find out.I'm just debating Striker Heads in spring 2012 or start my house reno's then. I'm starting to make my budget early.:hmmmm2:Kevin Singleton has plans but I don't know what they are (yet).
What are you working on Ron? any 10's. How is the new shop are you all moved in. And if the Strikers come out before spring be sure to call me I'll trailer my truck down if i have too if there's snow on the ground by then. I have my whole build visualized in my head and when it gets closer to crunch time then we'll talk numbers.Renos or Racing...The Age-Old Dilemma ...............
A TON of work coming in over the Winter, call me if you make it down.
Ronnie
