NukeGM/Ford
The bolt should be marked to indicate reverse thread.
Some have an CC arrow imprinted on the bolt head...
______
thanks
______
Universal bolt marking for reverse thread is notched corners on face of bolt.
It IS absolutely reverse threaded. Had many guys have to but a tensioner by stripping threads while breaking loose wrong way :rofl:
thanks, didn't know that
______
found a pic on here by moparracing
http://www.vtcoa.com/forums/f7/serpentine-belt-diagram-38055/
do the numbers on the pulleys indicate an order to install belt?? i have the routing correct but was trying to get it over the alternator as the last one since it was the smallest and easiest to get to……………..
maybe it would be easier to slide over the water pump since it has no ridges??
when i changed the belt on my 05 hemi it was a breeze……… or i just got lucky??
have to try after work today
I'm getting ready to do the coils and wires on my 06 QB I would love to know the tips on reinstalling the intake Thanks
Get me your email address and I can forward you the factory service procedure for removing and installing intake manifold.
boy it sure sucks working here this past week at 110, can't take it anymore, still to do list
1. final charge for batteryDONE
2. put inner rear fender back in around batteryDONE
3. finish cruise control installDONE
4. front drivers inner fender installDONE
5. black lug nuts
6. alignmentDONE
7. replace exhaustDONE
8. wire exhaust cutouts
9. decide on rear wing install
10. sand/prep/install hood
11. install Tonys shifter if it ever gets here
12. paint custom wheel center caps
13. install front sway bar
14. install under radiator tray
15. install black grill in new hood
damn, i thought the le=ist was getting shorter but it gets longer every time i type it:dontknow::dontknow::dontknow:
