REAR AXLE
It will have a new dana super 60 housing.
35 spline strange axles, with 5 x 5.5 bolt pattern.
Detroit locker with the machined surface for the ABS ring gear so we can maintain ABS.
Any ring gear ratio you want.(dana corp)
Spring perches welded on as well as shock mounts.
Ford axle end bearings.
Stock width axle.
any size pinion.
Price $2250
BRAKES
Have 3 choices.
Ford SVO, basically a small caliper
$400
Wildwood or aerospace caliper( better piston configuration)
$800
Both systems will allow for park brake and be able to install 15 inch rims.
WARRANTY
1 year manufacture warranty on all parts.
guarantee to fit.
10 year on axles.
Notes
The reason for a dana super 60 is it is available easily as far as housing and parts.
Detroit locker seems to be the best reliable way to go.
Should take about 2-3 weeks to build.
Reason for any pinion is he said he hasnt seen enough of the factory axles to take measurements to tell whether the driveshaft length will have to change or not, but probably not. If so the Driveshaft may have to be shortened or lengthened, but we did not do any measuring over the phone.
We will need to measure also for spring perches and shock mounts.
PRICE
complete axle $2250
Brakes
Ford SVO $400
Upgrade aerospace or wildwood $800
GROUP BUY!********************************************** **
AXLE $1950
Brakes ford $350
Upgrade wildwood or aerospace $650
HOW MANY PEOPLE?
We need 5 people to confirm a group buy, may go lower with more people.
End result price wise?
complete with ford $2650
compelte with upgrade $3050
WITH GROUP BUY******************************************
KILLER DEAL!!!!
complete with ford $2300
complete with upgrade $2600
What you will get is a rear axle combination where you can run a 15 inch rim if you wish and also have the piece of mind of a reliable axle combination.
Just need to know who may be interested. Basically if we get 5 people interested we can have a stong rear axle configuration with wildwood or aerospace brakes , any ring gear ratio, a locker differential, mounted ready to go for only $2600 or with the lesser ford combination at $2300!
Hard to freakin beat guys
__________________
How will this do buddy?
For only $2300 you can have a bullet proof rear axle, mounting up in the stock location, while retaining the stock look of the truck.
Plus able to get a detroiit bullet proof locker, and any ring gear combination you prefer:rock:
