FATJACK
Tooloe is right, great company to deal with, Dave is a big help.will answer all your questions.Tooloe said:www.nitrousoutlet.com... they make a plate kit for our trucks and dave will help ya out!
but don't ask a guy from tennessee...he prolly has duct tape holding the bottle downFATJACK said:I'm thinking....Yes
I use FRESH tape at every bottle refill, beotch!!viperhauler said:but don't ask a guy from tennessee...he prolly has duct tape holding the bottle down![]()
SANTEEN said:Someone correct me if I'm wrong, but I think we are at 58 psi.
Yea I remember hearing about running cooler plugs...which ones will do the trick?mmmmtorque said:Yup 60psi range...
BTW, its not a bad idea to dyno tune your nitrous set up if you plan to use it much. Of course it helps if you are using the VEC3 for windowing, timing and fuel management. Sometimes its hard to get an optimum 'safe' jet.
I pull timing and add fuel just before the nitrous window (3100-5500) as well post window through 6000rpms. Bottle pressure should be in the 900 range...
Run a cooler plug![]()
haha, I gotta chaneg plugs too. When you ready? I'll bring the beer.kickinassrt-10 said:Yea I remember hearing about running cooler plugs...which ones will do the trick?
I am definitely getting it dyno tuned for nos once I get the damn thing installed...
Sounds good to me...Let me knowSANTEEN said:haha, I gotta chaneg plugs too. When you ready? I'll bring the beer.
I guess I'm going with the ones that Paxton recommends, which may also be good for your application.:dontknow: NGK ZFR6F-11kickinassrt-10 said:Sounds good to me...Let me know![]()
What plugs are recommended?
jsut sent some stainless steel lines and ends to a good customer, make sure you fittings are gonna fit correctlysully1369 said:Not my post but im building a set up with lots of lines so I dont want to use steel braided and I wanna do it with hard lines, can I use brake lines?
nos is a touchy subject bud, one wrong word and you go boom and then they get the blamekickinassrt-10 said:Gonna have to research that....
I can't believe that with all the nitrous people all over the web i having such a bitch of a time getting info :dontknow:
That's not what I saw in Panama.Stinker said:nos is a touchy subject bud, one wrong word and you go boom and then they get the blame![]()
I just dont know enough about nos to help ya much bud![]()
LOL yeah but its mine if I blow it upSANTEEN said:That's not what I saw in Panama.![]()
