Stinker said:correct, but i keep hearing , 'what are you doing about the oiling issue?"
i keep asking "what issue?"
and havent gotten a good response yet.
i have rod bearings that look like oiling issues, but are a result of bad clearances during instalation.
in the bearings we are gonna use, the mains are grooved to "improve" oiling
and they are also coated to improve "life"
but I still dont see any issues yet with oiling, and I am sure there are some out there, i jsut havent been shown them yet:dontknow:
I haven't seen evidence of any oiling issues (yet?) but i don't do a large number of these engines either. No galling, discoloring, etc; normally associated with an oiling issue..
What I do see is detonation damage: "Spider-cracks" on the piston tops and in some cases, an outright cracking off of a portion of the top of the piston (which broke at the land in this case); which is back to fairly typical detonation damage.
The current victim broke a chunk out, jammed the piston in the bore and kicked a rod. Does this make the rods "bad"? not in my mind. Does it make the pistons defective? Nope.
