I'll at least set the record straight on why I'm doing the things I'm doing.
The first motor failure was from a destroyed oil pump. From talking with everyone within chrysler and certain others, this is a potential issue with these motors. There are people on the alley that lost stock motors to the exact same issue. At the time of the oil pump failure I had already made over 40 1/4 mile passes on the truck. The majority of these passes were in the low 11 second area. This was with the new rear and 10.5" slicks. I had indy go through the motor to make sure everything was ok. We had twisted the block, the main caps wouldn't budge. With the massive amount of tq made at low rpms and being able to hook it up, the block became the weak point for me. Had I made 10-20 runs, it might not have been an issue.
We send the oil pump to be cryo'd. The idiot did it wrong and made it so fragile, that I made it all of 400 miles driving it on the street. I had the cruise set driving down the interstate and oil went to 0. I just happen to be 2 miles from UG. I had the truck towed to their place. After talking with kevin, I simply decided to throw a paxton, with low boost. UG doesn't like using roe products. With that, I simply did whatever they wanted to do. At this point, I simply want the truck running and in one piece. I have zero desire to keep the truck, but I want it to be done right. My motor is coming back next week. I had new pistons put in, everything was fine, but they wanted new pistons.
I personally believe that SC to SC, the roe is the best for the track, assuming you did more mods to keep the block from twisting. I also believe it is best for a stock truck running low boost, simply for a fun factor. Brady is right in one factor, the more boost you run, by making the belt tighter, you will eventually pop the end of the crank. Once you have the balancer on the crank and then hang a pulley (the ATI only goes halfway on the crank), you have a LOT of leverage on the end of the crank. This is a piss poor design for maximizing power. It is a weak link any of these builds.
As far as Roe, I will never do business with them again. I really liked Sean as a person, however I disagree with the way they run their business. DC Performance has gone to some great lengths to help out customers if they ever had any issues. I spent over 45k bucks at Roe to be a test pig for this SC'er. Upon my second blow up, to which I called them on the side of the road, they never once returned a phone call or email. I looked at Sean and Dave as friends. I even bought dave a 354 hemi for his hotrod as a gift, because he's a hardcore car guy that I thought was cool. I had already said I was taking the truck to UG, simply due to logistic issues. Not once did I get a call to see how things were going, if things were ok and what not. Given that I prepaid a lot of things to help out with their cash flow situation when things were at their worse there, I at least expected the respect of a return phone call. I can say that all of my dealings with UG at this point have been flawless. I can't wait to work with them in the future on other projects.
Next week I close a deal on purchasing a drag strip. I'll make a post about potential dates for you guys to get in free and test all you want. Take it for what it's worth.
Mike
