pokeytemplar
Stinker said:abotu 700hp or so maybe a touch more. but the probs with the 48re is not its strength but the way the fluid pressures is handled.
it was designed for the doosals, which ramps pressure slowly, the strength of the tranny is awesome, but its fluid transfer is what needs work
Have you seen this new part? This pushes that limit up to 1200HP.
Dodge "RE" Governor Solenoid to GM Pressure Control Solenoid Conversion Kit
#REC. This kit was specifically designed to handle higher base pressure in high performance applications and to improve the reliability of the governor solenoid in normal use. In performance units the pressure can flood the Dodge solenoid and cause a no shift condition at full throttle. This is the fix. Fits all rear wheel drive RE model transmissions.
