Here are the pics of the newer version with some modifications.
That is the plate. But I enlarged the existing slots . I did not drill the 1/4" holes shown in the pic.
pokeytemplar said:Now for everyone one that states the intake is the problem are you talking about the intake above or below the supercharger?
bigike said:So that bolts to the bottom of the bloer instead of the lower plenum?
no thats in the bottom portion of the intake the top part is just a flat plate.bigike said:No el-answer-o?
that is basicly the same as the 2 plates but just one piece. Those are the holes I was thinking of doing the same thing to. Now I got yeah. Good to go.Thanks againblackviper said:Here are the pics of the newer version with some modifications.
Correct. I only made them wider. I made them wider by the area of a 1/4" hole.blackviper said:How much did you open up the slots? I imagine you used the the center of the existing slots and enlarged them outbound.
Prof said:As I look closer to my picture I believe the part we are talking about is missing. Note the groves in the back of the manifold...those are the mounting points for the part that directed the flow evenly to the various cylinders.
(Just below the donuts (Matt!)...
I seem to recall some comments about a possible patent action and that plate was still somewhat confidential...maybe I was dreaming that...
blackviper said:Just for clarification, you had the slots widened by a 1/4 inch total or by a 1/4 inch in each direction for a total of 1/2 an inch?
