SilvrSRT10
- Joined
- May 22, 2006
- Messages
- 6,865
- Reaction score
- 0
Everyone come to Rockingham, NC. April 12th is "Mopar at the Rock". I know......that's the same weekend as the SE GTG.1qksrt said:There's Moroso in West Palm!!!![]()
Exactly..its dangerous. Losing traction when you nail it around turns is no joke.Carlwalski said:Whoa! Back to topic......
My question seemed to be over looked. I don't want "1079rwhp" that's overkill in a big way for the street, what's the point? No traction, it's not all about hp but getting it to the ground a good driver with 650hp at the fly should be able to stomp a 1000hp+ car on the street.
I'm only after 650hp tops so 100-150hp at the fly over our 500hp stock output. Lots of posts about 990rwhp etc but that's more brag than good (until traction in these light arse rear ends are fixed).
Thanks,
Carl
Thanks,
Carl
still winter here 25 degrees today but the fla trip will be nice i should have plenty of seat time by thenRice Eater said:505 did you run your truck yet in the 1/4 or is it under construction?
nycstev said:If thats all you want just get the Roe unit . Its the simplest and probably least expensive and loads of fun and very reliable. I had it for a year now and I will be doing internals and boosting to 10 psi which should give in the low 700's. Thats fine for me.
505'sFastestViper. said:justin has not done a twin setup yet
well i have 3 different flashes for my truck street strip and on the street 800hp is plenty that is the great thing about this setup just swipe a card and there is your street tune ..............fill it with race gas push a button on the ams 1000 to change the boost and swipe the card and bam full blown race setup.....this truck could be tuned to 650 very easily with minimal boostCarlwalski said:My bad.That's kind of my topic though, does Justin offer smaller turbos?? Be good if he did, like, 3 different systems, street, street/strip and track. I like his work and the look of his set up but again, it's too much for a 100% street truck (in my opinion). I thought he may offer (or another vendor) a single turbo application that used a smaller turbo. :dontknow:
BurntRubber said:With the turbo you can also run different boost in each gear.
ex...1st gear 5psi, 2nd gear 8 psi, 3rd gear 11 psi, 4th gear 3,495psi...depending on your engine build![]()
